2011-06-09, 22:49
oroyce Wrote:I can't seem to find a xbmc.log file. When I open a link in XBMCflicks it kicks me out to IE where I log in but then when I go back to XBMC I can only choose CANCEL after which it just hangs requiring me to Ctrl-Alt-Del and ending the process (after memorizing the keyboard sequence 'cause I couldn't switch out of the XBMC screen. ANy help would be appreciated.
I am having the same issue on 2 XP machines. Did you find any resolution?
Quote:13:39:52 T:3104 M:365428736 NOTICE: Running with administrator rights
13:39:52 T:3104 M:365428736 NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
13:39:52 T:3104 M:365428736 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files\XBMC
13:39:52 T:3104 M:365428736 NOTICE: special://masterprofile/ is mapped to: C:\Documents and Settings\transfer\Application Data\XBMC\userdata
13:39:52 T:3104 M:365424640 NOTICE: special://home/ is mapped to: C:\Documents and Settings\transfer\Application Data\XBMC
13:39:52 T:3104 M:365424640 NOTICE: special://temp/ is mapped to: C:\Documents and Settings\transfer\Application Data\XBMC\cache
13:39:52 T:3104 M:365424640 NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
13:39:52 T:3104 M:365424640 NOTICE: Log File is located: C:\Documents and Settings\transfer\Application Data\XBMC\xbmc.log
13:39:52 T:3104 M:365424640 NOTICE: -----------------------------------------------------------------------
13:39:52 T:3104 M:365404160 NOTICE: Setup SDL
13:39:52 T:3104 M:365019136 NOTICE: Found screen: Plug and Play Monitor on Intel® Q965/Q963 Express Chipset Family, adapter 0.
13:39:52 T:3104 M:365170688 NOTICE: load settings...
13:39:52 T:3104 M:365088768 NOTICE: special://profile/ is mapped to: special://masterprofile/
13:39:52 T:3104 M:365072384 NOTICE: loading special://masterprofile/guisettings.xml
13:39:52 T:3104 M:364785664 NOTICE: Getting hardware information now...
13:39:52 T:3104 M:364785664 NOTICE: Checking resolution 12
13:39:52 T:3104 M:364773376 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
13:39:52 T:3104 M:364761088 NOTICE: Loaded playercorefactory configuration
13:39:52 T:3104 M:364761088 NOTICE: Loading player core factory settings from special://profile/playercorefactory.xml.
13:39:52 T:3104 M:364752896 NOTICE: Loaded playercorefactory configuration
13:39:52 T:3104 M:364744704 NOTICE: Loaded advancedsettings.xml from special://profile/advancedsettings.xml
13:39:52 T:3104 M:364744704 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videoextensions>
<add>.html</add>
</videoextensions>
</advancedsettings>
13:39:52 T:3104 M:364736512 NOTICE: Getting hardware information now...
13:39:52 T:3104 M:364736512 NOTICE: Checking resolution 12
13:39:52 T:3104 M:364736512 NOTICE: Default DVD Player: dvdplayer
13:39:52 T:3104 M:364736512 NOTICE: Default Video Player: dvdplayer
13:39:52 T:3104 M:364736512 NOTICE: Default Audio Player: paplayer
13:39:52 T:3104 M:364822528 NOTICE: Loading media sources from special://masterprofile/sources.xml
13:39:53 T:3104 M:318259200 NOTICE: initializing playlistplayer
13:39:53 T:3104 M:318246912 NOTICE: DONE initializing playlistplayer
13:39:53 T:3104 M:309886976 NOTICE: CApplication::UpdateLibraries - Starting music library startup scan
13:39:53 T:3104 M:309878784 NOTICE: initialize done
13:39:53 T:3104 M:309874688 NOTICE: Running the application...
13:39:53 T:3104 M:309854208 NOTICE: ES: Starting event server
13:39:53 T:3804 M:309780480 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
13:39:53 T:3804 M:309755904 NOTICE: UDP: Listening on port 9777
13:39:53 T:3860 M:304291840 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:00
13:40:02 T:3392 M:294678528 NOTICE: -->Python Interpreter Initialized<--
13:40:02 T:3392 M:290430976 NOTICE: ##########################################################
13:40:02 T:3392 M:290430976 NOTICE: Arg1: 0
13:40:02 T:3392 M:290430976 NOTICE: Arg2:
13:40:02 T:3392 M:290418688 NOTICE: Mode: 0
13:40:02 T:3392 M:290418688 NOTICE: ##########################################################
13:40:03 T:3400 M:292208640 NOTICE: -->Python Interpreter Initialized<--
13:40:03 T:3400 M:291172352 NOTICE: ##########################################################
13:40:03 T:3400 M:291168256 NOTICE: Arg1: 0
13:40:03 T:3400 M:291168256 NOTICE: Arg2: ?mode=0
13:40:03 T:3400 M:291160064 NOTICE: Mode: 0
13:40:03 T:3400 M:291160064 NOTICE: ##########################################################
13:40:04 T:2480 M:283344896 NOTICE: -->Python Interpreter Initialized<--
13:40:05 T:2480 M:282529792 NOTICE: ##########################################################
13:40:05 T:2480 M:282529792 NOTICE: Arg1: 0
13:40:05 T:2480 M:282529792 NOTICE: Arg2: ?mode=20
13:40:05 T:2480 M:282529792 NOTICE: Mode: 20
13:40:05 T:2480 M:282525696 NOTICE: USER INFO FILE LOC: C:\Documents and Settings\transfer\Application Data\XBMC\userdata\addon_data\plugin.video.xbmcflicks\userinfo.txt
13:40:05 T:2480 M:282525696 NOTICE: couldn't load user information from userinfo.txt file
13:40:05 T:2480 M:282525696 NOTICE: .. getAuth called ..
13:40:05 T:2480 M:282525696 NOTICE: OSX Setting is set to: False
13:40:05 T:2480 M:282525696 NOTICE: .. user configured ..
13:40:06 T:2480 M:283213824 NOTICE: Token did not contain any errors
13:40:07 T:2480 M:273506304 NOTICE: browser open has completed
