2012-12-11, 03:23
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
2012-12-11, 05:04
Yabsie. I'm on mac osx, frodo beta 3.
I installed your new addon, followed instructions but I am unable to find the user info file in the location you had specified. Also now I'm getting a script error now.
What am I doing wrong?
2012-12-11, 05:15
(2012-12-11, 05:04)ozkhan1 Wrote: [ -> ]Yabsie. I'm on mac osx, frodo beta 3.
I think on mac OS its in
/Users/USERNAME/Library/Application Support/XBMC/userdata/addon_data/plugin.video.xbmcflicks/userinfo.txt
where USERNAME is your username
if not turnup debugging and check the log it should say where its looking or post log here
2012-12-11, 05:23
Where is the log recorded? I have debugging turned on
2012-12-11, 05:40
(2012-12-11, 05:23)ozkhan1 Wrote: [ -> ]Where is the log recorded? I have debugging turned on
on mac? not 100% sure,
look in /Users/USERNAME/Library/Application Support/XBMC maybe
if not search the whole computer for xbmc.log
2012-12-12, 16:09
(2012-12-10, 08:18)tkbrit Wrote: [ -> ](2012-12-07, 17:32)yabsie Wrote: [ -> ]coming soon,
- Saved/named searches
- filtering on browse by genre
- Search by person (director actor ) filtering by all movie search criteria
- Global limits on all of these search criteria (parental control)
yabsie, thanks for all the hard work on this! Keep it up
Personally, I am still having issues with the instant queue not working. I can launch movies from the top 25 of netflix, but my personal queues dont load. When i go to the error log I get something like "403, user not active" which is shennigans lol. I had to manually create my userinfo.txt file though as it wouldnt grab it through chrome.
Thoughts?
can you post that a log for this with debugging cranked up and I will have a look the "user not active" is pointing towards some sort of authentication error
2012-12-12, 20:56
I can't get it to work... It might be because of my location, Sweden?
I've installed it but when im about to "register" my netflix account i get "Script failed"
I'm using Windows 7 64bit, google chrome, and netflix in sweden
Quote:19:48:50 T:2900 NOTICE: root folder: C:\Users\Burk\AppData\Roaming\XBMC\addons\spudsdude-XBMC-Flicks-a644263
19:48:50 T:2900 NOTICE: working folder: C:\Users\Burk\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\
19:48:50 T:2900 NOTICE: links folder: C:\Users\Burk\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\links
19:48:50 T:2900 NOTICE: real link path: C:\Users\Burk\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\links
19:48:50 T:2900 NOTICE: resource folder: C:\Users\Burk\AppData\Roaming\XBMC\addons\spudsdude-XBMC-Flicks-a644263\resources
19:48:50 T:2900 NOTICE: lib folder: C:\Users\Burk\AppData\Roaming\XBMC\addons\spudsdude-XBMC-Flicks-a644263\resources\lib
19:48:50 T:2900 NOTICE: userinfo folder: C:\Users\Burk\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\
19:48:50 T:2900 NOTICE: USER INFO FILE LOC: C:\Users\Burk\AppData\Roaming\XBMC\userdata\addon_data\plugin.video.xbmcflicks\userinfo.txt
19:48:50 T:2900 NOTICE: couldn't load user information from userinfo.txt file
19:48:50 T:2900 NOTICE: .. getAuth called ..
19:48:50 T:2900 NOTICE: OSX Setting is set to: False
19:48:50 T:2900 NOTICE: .. user configured ..
19:48:51 T:2900 NOTICE: Token did not contain any errors
19:48:51 T:2900 NOTICE: browser open has completed
19:48:59 T:2900 NOTICE: The dialog was displayed, hopefully you read the text and waited until you authorized it before clicking ok.
19:48:59 T:2900 ERROR: Error Type: <class 'httplib.BadStatusLine'>
19:48:59 T:2900 ERROR: Error Contents:
19:48:59 T:2900 ERROR: Traceback (most recent call last):
File "C:\Users\Burk\AppData\Roaming\XBMC\addons\spudsdude-XBMC-Flicks-a644263\default.py", line 26, in <module>
import resources.lib.menu as menu
File "C:\Users\Burk\AppData\Roaming\XBMC\addons\spudsdude-XBMC-Flicks-a644263\resources\lib\menu.py", line 474, in <module>
getInstantQueue()
File "C:\Users\Burk\AppData\Roaming\XBMC\addons\spudsdude-XBMC-Flicks-a644263\resources\lib\iqueue.py", line 1379, in getInstantQueue
initApp()
File "C:\Users\Burk\AppData\Roaming\XBMC\addons\spudsdude-XBMC-Flicks-a644263\resources\lib\iqueue.py", line 1374, in initApp
user = getAuth(netflixClient,VERBOSE_USER_LOG)
File "C:\Users\Burk\AppData\Roaming\XBMC\addons\spudsdude-XBMC-Flicks-a644263\resources\lib\iqueue.py", line 85, in getAuth
tok = netflix.user.getAccessToken( MY_USER['request'] )
File "C:\Users\Burk\AppData\Roaming\XBMC\addons\spudsdude-XBMC-Flicks-a644263\resources\lib\Netflix.py", line 74, in getAccessToken
response = client.connection.getresponse()
File "C:\Program Files (x86)\XBMC\system\python\Lib\httplib.py", line 990, in getresponse
response.begin()
File "C:\Program Files (x86)\XBMC\system\python\Lib\httplib.py", line 391, in begin
version, status, reason = self._read_status()
File "C:\Program Files (x86)\XBMC\system\python\Lib\httplib.py", line 355, in _read_status
raise BadStatusLine(line)
BadStatusLine
19:48:59 T:4984 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.xbmcflicks/?mode=10
19:48:59 T:4984 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.xbmcflicks/?mode=10) failed
19:48:59 T:3720 NOTICE: -->Python Interpreter Initialized<--
19:49:00 T:3720 NOTICE: ##########################################################
19:49:00 T:3720 NOTICE: Arg1: 0
19:49:00 T:3720 NOTICE: Arg2: ?mode=0
19:49:00 T:3720 NOTICE: Mode: 0
19:49:02 T:5260 NOTICE: -->Python Interpreter Initialized<--
19:49:02 T:5260 NOTICE: ##########################################################
19:49:02 T:5260 NOTICE: Arg1: 0
19:49:02 T:5260 NOTICE: Arg2:
19:49:02 T:5260 NOTICE: Mode: 0
2012-12-13, 05:53
(2012-12-10, 01:31)MrDamnation Wrote: [ -> ](2012-12-07, 23:17)mooncaptain Wrote: [ -> ]Regarding embedding Netflix player inside of XBMC in the same way Hulu is embedded. I am sure that in some way or other this can be accomplished technically but... Netflix specifically prohibits using their API if the target application is going to embed the viewer in a 3rd party app. Basically they insist that the API user view through a browser. I am guessing that a special license would get you around this restriction.
Thanks for that information. Maybe someone should take up a cause and get to Netflix regarding this. Sounds like the low-risk, high-reward action I could take that doesn't require much of my non-existent time.
This is why I switched to Amazon. Netflix should know that they are losing customers through this unwise practice.
2012-12-14, 01:20
(2012-12-12, 20:56)victorbre Wrote: [ -> ]I can't get it to work... It might be because of my location, Sweden?
getInstantQueue()
initApp()
response.begin()
BadStatusLine
Search the. Last few pxages for userinfo.txt. Sorry for terse reply I am at the rink using a phone and its tough using this forum.
2012-12-15, 13:10
finally was able to setup for mexico, kind of odd browsing for a movie and the one you like to watch is not for you contry lol
2012-12-15, 14:28
yabsie: i quickly hacked in linux support via netflix-desktop(https://launchpad.net/netflix-desktop) on my local copy of xbmcflicks, it's working just fine, maybe interested in adding this to your fork after i cleaned this up a little to make it easier for other linux users?
2012-12-17, 15:29
(2012-12-15, 14:28)fldc Wrote: [ -> ]yabsie: i quickly hacked in linux support via netflix-desktop(https://launchpad.net/netflix-desktop) on my local copy of xbmcflicks, it's working just fine, maybe interested in adding this to your fork after i cleaned this up a little to make it easier for other linux users?
I want! No, but seriously I would really like to try out netflix in xbmc, but as I have understood as long as I'm on a linux disto it won't work.
Looking forward to you sharing this with the rest of us :-)
2012-12-17, 15:47
yup, send it in when you get the chance
2012-12-18, 14:32
I have installed this add-on on my mac mini 2011, running Frodo RC1 and went through all the procedures to register my API key and secret manually in in the iqueue file. Now I can search and browse the new arrivals, watch a movie... but the instant queue are displaying an empty folder, is this a known bug?
Also what I am trying to achieve is to open a dedicated ssb app that I have created using that script http://www.lessannoyingcrm.com/articles/..._generator
instead of my default browser, is there a way to change/hardcode the app to launch?
2012-12-18, 22:43
(2012-12-18, 14:32)lucanoid Wrote: [ -> ]Hi,<snark>
know whats super cool about this forum? the search feature! or even the scroll back half a page feature!
</snark>
Neither frodo or mac or technically supported in this version, I may formally support mac once one of you fine folks mail me computer to test on.
ooo...I guess that was snarky too, *shrug*
