Full Version: How can I set the button weather automatically active in the homeblade?
Hi, I try to change the home.xml that after the start of xbmc the weather button is active (have focus) so my weather fanarts show automatically.
By default the music button is active.
I hope anyone have the experience how must I change for this behavior.
Thanks for your help
Regards Zippolighter
You need to change the order that it appears in home.xml. Swap the music and the weather sections in the grouplist and you should be good. May take some playing with to get it the way you want.
Hi thanks for the answer,
but this is not a solution for me.
I like the order and will not change the order.
I look for the possibility to only set the weather active after the startup of xmbc.
