Someone wanna find me a free wordpress feature request plugin.
This would be perfect
http://codecanyon.net/item/avia-feedback...ref=Kriesi
I should be able to easily edit that to allow for submitting bugs as well which would make it easier for me to track these things.
But its $25, and I don't have that, so that's the baseline sort of thing we are looking for.
I could easily write one myself, but there are enough things to do at the moment that I'd prefer to just hack something existing.
*edit*
No one was very forthcoming, so I just ended up paying for it =/
http://fanart.tv/feedback/
Add your feature requests there.
You also get 10 votes a month to pick the features you want the most
*edit* its not currently working properly, so any votes will be flushed when i have fixed it
lol, you do look like someone who would want a pony.
The voting bit seems to be messed up, it seems to just randomly set it back to 10 votes available
Kode Wrote:Which ones? You might have submitted duplicates.
Yeah, you found two that were duplicates last night. I will keep an eye out for how that happened.
Ok i've reset the votes, I changed the way it worked, before it created a setting for each user with their current votes left and also incremented a votes table based on feature id and user id, then monthly truncated the settings which seemed flakey, so instead it now creates a new entry every time you vote and it uses those to see how many you have done this month and how many you have left.
I dunno, you spend $25 on these things, you don't expect to have to make it work as well
I think the work had been done to get anonymous voting based on IP and member only voting was an afterthought.
Anyways, it should be sorted now, so get adding any features that are missing.
Kode, if you do not add images to the site and select request, you get something that says nup, yet yes..
http://img828.imageshack.us/i/yesnog.png/
Do you think, you will add clear logos for movies?
I am skipping through my movies now, and wish they were there :p
The topic of logos for movies has come up before. Personally I think that another group entirely should handle that kinda thing. We've got enough on our plate as is and there probably aren't too people capable of making them actually interested. The number of crappy logos would go up as people tried to rush through their massive collections of films. Atleast with tv/web series there's a reasonably finite number of them. But with movies the task is insurmountable.. people would just keep requesting and requesting and submitting shit logo after shit logo. It would literally never end.
Just a quick question about ClearArt, what, how and where do I see this in XBMC? I'm using the Night skin.
MarkAsRead Wrote:Just a quick question about ClearArt, what, how and where do I see this in XBMC? I'm using the Night skin.
Pause screen, if you have them stored correctly - Top level of TV Show folder and called clearart.png - it'll show automatically....
mcborzu Wrote:Pause screen, if you have them stored correctly - Top level of TV Show folder and called clearart.png - it'll show automatically....
Great thanks!
I've made some for my Fav show, One Piece, Wonder if they will make the cut.
-edit-
So I created and uploaded 12 One Piece ClearArts, enough for today.
For shows that just don't have any logo, are we allowed to create something that looks better? I am finding that a lot are just in plain text pulled from thetvdb, and they were just created on the fly as there was no source.
e.g
http://fanart.tv/fanart/85356/source/sou...e098d3.jpg
Not going to get too creative, as that would take forever, but a better looking font then arial or even just a small effect on it so they stand out and you can distinguish between them..
UserInterface Wrote:For shows that just don't have any logo, are we allowed to create something that looks better? I am finding that a lot are just in plain text pulled from thetvdb, and they were just created on the fly as there was no source.
e.g
Yea that didn't seem to be the correct font, alot of those very obscure shows seem to have just common Arial on the banners,
THIS seems to be a better source and very common font also....
Looks like Times or something similar to me :p
The feedback system works like this for those of you who don't hover over the info icon:
Each month you get 10 votes to distribute. You can choose to use all your votes for one idea you really like, or spread them across between several ideas.
You can also create new requests by clicking on "Add entry", the 4 icons at the top left allow you to sortby/filter the requests.
