2011-10-23, 12:47
http://www.youtube.com/user/fanartdottv this is the new channel for fanart.tv video tutorials, hopefully we will be able to put a few more up there
mad-max Wrote:Hey Kode,Will definitly giva that a try. Does this also reduce the file size because that was my biggest problem so far. Keeping it under 600kb
hey all others around...
I don't know if it's a help, but regarding cdarts, one of our xbmcnerds.com users made a gimp-fu script for cdarts...
hope this helps...
cheers,
mm
Machine-Sanctum Wrote:Will definitly giva that a try. Does this also reduce the file size because that was my biggest problem so far. Keeping it under 600kb
mad-max Wrote:To be honest, I never cared about the file-size, so I did not check, yet...
but this would be quite easy for all users I guess...the worst part is done by the script...or someone takes the script as a basis and develops it further to also reduce the size under 600kb...
mm
just copy the script to \~\GIMP-2.0\share\gimp\2.0\scripts\
restart gimp
and then you have a button "cd" in the menu...then just opening the png from what you want to extract the cdart and click the button...finished...
if it doesn't fit, there's a slider to adjust the size of the cutted area...
you can find the script over at xbmcnerds.com in the download-database, exactly here:
http://www.xbmcnerds.com/index.php?page=...&dataID=36
hope this helps...
cheers,
mm
jacktyler Wrote:Hi biochip,
I've started making a CDart video tutorial. CDarts aren't my speciality though, so it may take me a day or so to do it. I'll upload it as soon as it's done (might be later today, might be tomorrow).
I'll aim to make it about 15 minutes - it could be shorter, but I intend to cover 3 different types of the most common CD design.
Jack
Kode Wrote:If you want to know what skins use fanart.tv artwork here is a list http://fanart.tv/skin-support/
mad-max Wrote:Hey kode,
wanted to know if you can set my confluence-mod to the list of supporting cdart...
you might check my sig to get a quick view...or take a look here:
http://www.xbmcnerds.com/index.php?page=...eadID=5015
would be nice if this is possible...
cheers,
mm
biochip Wrote:hi, how is going with tutorial? I will have a lot of free time in the weekend to make some CDs.
Kode Wrote:Of course mate If you let me know what to tick and what to cross I'll sort that out for you.
mad-max Wrote:Great...here we go with the ticks:
tv-show: clearlogo, clearart
btw: what's tv-thumb? maybe my skin supports it and I don't know
music:clearlogo, cdart, albumcover, extrafanart(extrafanart is coming in the next release, but can be ticked as I is not far from being released )
rest is cross, though not much left...
Thanks for the help...
mm
