Full Version: fanart.tv - Request and share ClearLOGO, ClearART and more Fan Artwork / Thumbs
@Kode
I uploaded some cdart however i just found out the great template from Giftie. So could you (or someone else) please reject the cdart uploaded by my untill november 26?
I will redo them in a proper way
If it's any help, here is my own version of Giftie's excellent template (and credit to Sekhmet too).
It is built from the bottom-up in GIMP. The circles are smoother (mathematically perfect) and the shadows are more even.
I have also added paths for the rings, which are extremely useful when you are trying to position things - you can just make the paths visible and it gives you a useful guide.
Everything else works exactly as Giftie's tutorial.
http://dl.dropbox.com/u/3513016/Fanart/f...ate-JT.xcf
jacktyler Wrote:If it's any help, here is my own version of Giftie's excellent template (and credit to Sekhmet too).
So what layers do i need to use or not use? Because disc shadow is off
Had some problems because the white layers was visble so screwed up some cdarts.
What do I do, when my logo isn't associated with a TV-show?
Tobby Wrote:What do I do, when my logo isn't associated with a TV-show?
What do you mean?
If it isn't on fanart.tv do this:
Kode Wrote:http://fanart.tv/topic/cant-add/
http://fanart.tv/topic/cannot-find-show/#post-769
http://fanart.tv/topic/adding-music-artists/#post-949
If not on thetvdb.com add it there first.
Machine-Sanctum Wrote:What do you mean?
I uploaded it, but something must have went wrong, because it's not assosciated with any TV-show.
Show:
File: -4ecd42d8e2a6a.png
Author: Tobby
Approved by: jacktyler
Tobby Wrote:I uploaded it, but something must have went wrong, because it's not assosciated with any TV-show.
Show:
Author: Tobby
A link to the file and show in question would be the first step...
Also it probably just means there is no english title for the show, it should still work though.
There are currently 66 shows with no english title.
Machine-Sanctum Wrote:So what layers do i need to use or not use? Because disc shadow is off
My bad, I perhaps should have turned the white layer off, I have now. The "Disc shadow" layer is purely optional, I have added the word "OPTIONAL" to it - I personally, never use it).
The rest of the "shadow" layers go from the outside in, so from 2nd to 1st to hole shadow.
You must remember, NO template is perfect as it stands - they are designed to apply certain constraints and to help get other bits right - you WILL need to resize shadow layers to get them aligned to your particular disk. Smile
jacktyler Wrote:My bad, I perhaps should have turned the white layer off, I have now. The "Disc shadow" layer is purely optional, I have added the word "OPTIONAL" to it - I personally, never use it).
No problem. I must had payed some more attention when using it Wink
It works great. I'm halfway my collection now Smile
I know I have been promising for ages to do a tutorial on Cd arts and I have started, but I've been held up a bit by a major cumputer failure, where my watercooler decided to leak all over my components, so it's thrown me off schedule slightly! It's taken me a few months to replace the motherboard and the GPU (CPU survived thank goodness!) but I'm getting there, I haven't forgotten Smile
looking forward to it jack Smile
I've managed to get some work done on the new site, so it's finally starting to take shape Smile
I'd like to use your tutorial and template on the new site so whenever you are ready Wink
As posted on the fanart.tv forums
Quote:We are going to be adding language support on the new site, so we need to tag all the current tv images with the right language.
You can all help out by going to http://fanart.tv/api/language_fix_tv.php a random set of 40 images will be loaded with english set by default, please check the images and change any that need changing, if there are any you don’t know the language of, change it to Unknown.
This won’t actually set it to anything, so it will come up again, but other users might know what the image is and you are unlikely to come across it again until the amount of images to process is a lot smaller
You need to be logged in to see the list.
You need to be registered and logged in to help.
As of this post there are 11,150 images that need tagging, so we would appreciate your help in this.
If you aren't sure of the language please don't guess, just set it to unknown.
Early access to the new site as posted here: http://forum.xbmc.org/showthread.php?tid=116335
Just saw this! Thanks Jack, it's great, I'll use it from now on.
GIMP template for creating cdart with transparent outer rings and step by step guide
GIMP Template Transparen outer ring.zip
This is an updated version of Jacks template
Thank to Giftie/Jacktyler
