2010-12-14, 11:16
Hi, i have build my own htpc on Asus AT3IONT-I with ubuntu and xbmc.
When i was working on my 24'' lcd monitor, everythink was ok, however, when i connected it to my philips lcd tv, horizontal flickering line appears from time to time. It's a little disturbing for me.
I have done some research on google and set the VSync and everything in nvidia driver setting and also in XBMC. However it did not help.
So i have done a little more digging, i have found out, that when i put xbmc in full screen mode, it uses resolution 1280x768. However, my tv is only 1280x720. So i set the right resolution, it seemed to work ok(definetely it was better). But when i went to non full screen mode and then back to full screen, the bad resolution was there again.
Could you possibly help me how to set xbmc to use 1280x720 on full screen as default?
Secondly, have you any idea what else should i do, if the horizontal flickering line appears also on correct resolution.
