2005-01-03, 18:17
2005-01-04, 12:29
come on someone must know how to start a script , i am running he latest version but in the general settings there is no scripts bit
2005-01-04, 12:49
choose "scripts" or simillar under the submenu button, then just locate your script by browsing...
or you need to edit the xml files and add the specific script to the dialogsubmenu.xml file. which xml file it is depends on which skin you are using.
