I installed dharma RC2 but I can not find the option how to enable the LCD. The LCD worked before and I think the LCD option was in settings -> system but it is not there.
LCDd is running and the LCD shows the heartbeat and all but nothing from xbmc. How can I tell xbmc to use the LCD?
I sort of solved it. After manually setting haslcd to true in guisettings.xml the LCD works.
However the option to enable the LCD still does not show up in the settings -> system menu.
I installed Dharma final and there is still no option in the settings to enable a lcd.
I tried bored's workarround, but after a reboot the guisettings.xml has changed to "false" again in the "haslcd" line.
Only LCDProc is showing in the lcd that it is running. I googled the whole www for a solution, but most HowTos talk about setting up the lcd in the system menu. Help!
It's been made hidden, a lot of users turned it on without knowing what it does.
bobo1on1 Wrote:It's been made hidden, a lot of users turned it on without knowing what it does.
So where can I enable it, cause I think I know what I do.
Editing guisettings.xml should work ok, as long as you don't have xbmc running while you edit it.
OK, my fault was to edit the file over a ssh client while xbmc was running.
It works now. Thanks for the help!
