2010-12-15, 22:40
Hello,
I am using Dharma RC2, and trying to add a second RSS feed in order to display weather forecast. Unfortunately, no matter what configuration I use, all RSS feeds show exactly the same data.
Here is my RSSFeeds.xml
If I look at the debug XBMC.log, I notice that only one URL is fetched :
There is no reference at all to the second feed in the log file. If I switch the set IDs, then the second feed is displayed twice on the screen, and only this one is referenced in the XBMC.log file.
I found this 2008 thread which seem to report the same problem.
Am I doing anything wrong or is this a bug?
Thank you.
V.
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<rssfeeds>
<!-- RSS feeds. To have multiple feeds, just add a feed to the set. You can also have multiple sets. !-->
<!-- To use different sets in your skin, each must be called from skin with a unique id. !-->
<set id="1">
<description>feedburner</description>
<feed updateinterval="30">http://p.yimg.com/dj/rss/</feed>
</set>
<set id="2">
<description>meteo</description>
<feed updateinterval="30">rss://localhost/meteo/rss.php</feed>
</set>
</rssfeeds>
Quote:21:25:57 T:2977418096 M:2692763648 DEBUG: FileCurl::Open(0xb177b118) http://p.yimg.com/dj/rss/
21:25:57 T:2977418096 M:2692763648 INFO: easy_aquire - Created session to http://p.yimg.com
21:25:58 T:2977418096 M:2690211840 DEBUG: FileCurl::Close(0xb177b118) http://p.yimg.com/dj/rss/
21:25:58 T:2977418096 M:2690211840 DEBUG: Got rss feed: http://p.yimg.com/dj/rss/
21:25:58 T:2977418096 M:2689957888 DEBUG: RSS feed encoding: UTF-8
21:25:58 T:2977418096 M:2689957888 ERROR: convert_checked failed from UTF-8 to UTF-8, errno=84
21:25:58 T:2977418096 M:2689957888 ERROR: convert_checked failed from UTF-8 to WCHAR_T, errno=84
21:25:58 T:2977418096 M:2689703936 DEBUG: Parsed rss feed: http://p.yimg.com/dj/rss/
Thank you.
V.
