A few questions that I hope you can help with:
Any information that you can provide on what causes Emutopia to crash when trying to start a game? I can't say a particular game as of yet, but every now and then either the emulator doesn't do anything, or it freezes and I have to restart XBMC.
Also...about the scraper. It's not working...for anything that I have. Oh wait, I was able to scrape info for about 3 games, but that's it.
I may have to watch a few google python tutorials on youtube...Catch up and help you out with the coding!
Some of the emulators seem to be a hit and miss even though there's plenty of documentation available online. I'll just have to play with it some more.
Thanks for the work that you did on this.
Any chance you would like to add thegamesdb.net as a scrape source?
Getting script errors when trying to import collection, scan new games and running addon. Tried using the October 3rd nightly build, Windows 7 32-bit.
Debug log here:
http://pastebin.com/zP5iUKyV
Me too. Using October 18th nightly build, none of the scripts work - I am only able to configure the add on and add rom collections but every action from scraping to actually running emulatopia, returns an error.
Relevant lines from the log:
Quote:09:58:20 T:2568 NOTICE: -->Python Interpreter Initialized<--
09:58:20 T:2568 ERROR: Error Type: <type 'exceptions.ImportError'>
09:58:20 T:2568 ERROR: Error Contents: DLL load failed: Impossibile trovare il modulo specificato.
09:58:20 T:2568 ERROR: Traceback (most recent call last):
File "C:\Users\andrea\AppData\Roaming\XBMC\addons\script.games.emulatopia\default.py", line 24, in <module>
import gui
File "C:\Users\andrea\AppData\Roaming\XBMC\addons\script.games.emulatopia\resources\scripts\gui.py", line 5, in <module>
from collection import *
File "C:\Users\andrea\AppData\Roaming\XBMC\addons\script.games.emulatopia\resources\scripts\collection.py", line 2, in <module>
import tempfile, py7zlib
File "C:\Users\andrea\AppData\Roaming\XBMC\addons\script.games.emulatopia\resources\platform_libraries\win32\py7zlib.py", line 28, in <module>
import pylzma
ImportError: DLL load failed: Impossibile trovare il modulo specificato.
09:58:41 T:5296 WARNING: Trying to add unsupported control type 3
09:58:43 T:5060 WARNING: Previous line repeats 8 times.
09:58:43 T:5060 WARNING: XFILE::CFileFactory::CreateLoader - Unsupported protocol(addons) in addons://more/executable.tbn
09:58:49 T:5296 WARNING: Trying to add unsupported control type 3
10:00:42 T:5296 ERROR: Control 1 in window 10099 has been asked to focus, but it can't
10:00:55 T:5296 WARNING: Trying to add unsupported control type 3
10:00:55 T:1348 WARNING: Previous line repeats 7 times.
10:00:55 T:1348 WARNING: XFILE::CFileFactory::CreateLoader - Unsupported protocol(addons) in addons://more/executable.tbn
10:01:01 T:5296 WARNING: Trying to add unsupported control type 3
10:01:24 T:5296 WARNING: Previous line repeats 8 times.
10:01:24 T:5296 ERROR: unmatched parentheses in IntegerGreaterThan(Container(9).NumItems),0)
10:01:30 T:6000 NOTICE: -->Python Interpreter Initialized<--
10:01:30 T:6000 ERROR: C:\Program Files (x86)\XBMC\system\python\Lib\ntpath.py:477: DeprecationWarning: os.getcwd() currently lies to you so please use addon.getAddonInfo('path') to find the script's root directory and DO NOT make relative path accesses based on the results of 'os.getcwd.'
path = os.getcwd()
10:01:30 T:6000 ERROR: C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib\pysqlite2\__init__.py:21: UserWarning: For some reason the module 'pysqlite2' couldn't get access to '__main__'. This may prevent certain backward compatility modes from operating correctly.
warnings.warn("For some reason the module '" + str(__name__) + "' couldn't get access to '__main__'. This may prevent certain backward compatility modes from operating correctly.")
10:01:30 T:6000 ERROR: C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib\pysqlite2\__init__.py:34: UserWarning: DeprecationWarning: the pysqlite2 module is deprecated; please change your script to use sqlite3.
warnings.warn("DeprecationWarning: the pysqlite2 module is deprecated; please change your script to use sqlite3.")
10:01:30 T:6000 ERROR: Error Type: <type 'exceptions.ImportError'>
10:01:30 T:6000 ERROR: Error Contents: DLL load failed: Impossibile trovare il modulo specificato.
10:01:30 T:6000 ERROR: Traceback (most recent call last):
File "C:\Users\andrea\AppData\Roaming\XBMC\addons\script.games.emulatopia/resources/standalone/importScript.py", line 13, in <module>
import pylzma
10:01:34 T:4696 NOTICE: -->Python Interpreter Initialized<--
10:01:34 T:4696 ERROR: C:\Program Files (x86)\XBMC\system\python\Lib\ntpath.py:477: DeprecationWarning: os.getcwd() currently lies to you so please use addon.getAddonInfo('path') to find the script's root directory and DO NOT make relative path accesses based on the results of 'os.getcwd.'
path = os.getcwd()
10:01:34 T:4696 ERROR: C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib\pysqlite2\__init__.py:21: UserWarning: For some reason the module 'pysqlite2' couldn't get access to '__main__'. This may prevent certain backward compatility modes from operating correctly.
10:01:34 T:4696 ERROR: C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib\pysqlite2\__init__.py:34: UserWarning: DeprecationWarning: the pysqlite2 module is deprecated; please change your script to use sqlite3.
10:01:34 T:4696 ERROR: Error Type: <type 'exceptions.ImportError'>
10:01:34 T:4696 ERROR: Error Contents: DLL load failed: Impossibile trovare il modulo specificato.
10:01:34 T:4696 ERROR: Traceback (most recent call last):
File "C:\Users\andrea\AppData\Roaming\XBMC\addons\script.games.emulatopia/resources/standalone/scrapeScript.py", line 13, in <module>
import pylzma
10:01:47 T:5296 WARNING: Trying to add unsupported control type 3
