Full Version: Some videos scaled down in left corner.
Hi after i got new video card alot of my videos are displayed scaled and played in the top left corner(see picture link http://picasaweb.google.com/fathamster00...1013697554 )
I have made a Debug log (
http://pastebin.com/sJYhmveE )
Im running a Windows 7, 32-bit on a ABIT Fatal1ty F-I90HD
Core 2 Duo - E6320 - 4MB - 1.86Ghz
2 Gigs of ram
ASUS GEFORCE GT 430 1GB PCI-E
im using the Hdmi out to a DENON AVR-1911
Tv is a Samsung UE47B7070
XBMC Revision SVN:35566
What do i need to do to get it working again?
Loking through the log i find 2 lines with error. dont know ifthis is the reason or?
ffmpeg[24E4]: [h264] Cannot parallelize deblocking type 1, decoding such frames in sequential order
CWin32DirectSound::Initialize: Couldn't create secondary buffer (DSERR_UNSUPPORTED). Trying without CTRLVOLUME.
The same thing happens on some Ions and it has to do with the graphics drivers - nvidia or OEM (Asrock, asus, etc.)
So try other drivers if you can.
That happens only when hardware acceleration (dxva) is used by the way, so if your CPU is strong enough, you can try disabling that option.
Thank you CrystalP, i will try to use an older / beta driver. the 430 is a reltive new card maybe a beta driver will solve it.
im reather sure i tried to turn off dxva rendering and same resuls, but will try your suggestion when i get home Smile
Im having the same issue.
The latest beta drivers solve the rendering issue, but the playback is a bit jumpy now.
For now I have disabled DXVA2 which seems to do the trick.
I hope this is an easy bug to squash, and hopefully once the drivers are out of beta it will be fixed.
