OK now after reboot starting XBMC results in an instant crash and error log.
I see error messages about the remote keymapping which I had customized 1 key on and another error message about a window translator but have no idea what that is. The stack trace ends at the remote so I'll go get rid of my customization and see what happens I guess.
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Fri Dec 17 00:25:47 PST 2010
XBMC Options:
Arch: x86_64
Kernel: Linux 2.6.35-23-generic #41-Ubuntu SMP Wed Nov 24 11:55:36 UTC 2010
Release:
Distributor ID: Ubuntu
Description: Ubuntu 10.10
Release: 10.10
Codename: maverick
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/strider/core (2010-12-17 00:25:46.906269999 -0800)
[New Thread 2216]
Core was generated by `/usr/lib/xbmc/xbmc.bin'.
Program terminated with signal 11, Segmentation fault.
#0 0x00000000007cc405 in std::_Rb_tree<CStdStr<char>, std::pair<CStdStr<char> const, std::map<CStdStr<char>, CStdStr<char>, std::less<CStdStr<char> >, std::allocator<std::pair<CStdStr<char> const, CStdStr<char> > > > >, std::_Select1st<std::pair<CStdStr<char> const, std::map<CStdStr<char>, CStdStr<char>, std::less<CStdStr<char> >, std::allocator<std::pair<CStdStr<char> const, CStdStr<char> > > > > >, std::less<CStdStr<char> >, std::allocator<std::pair<CStdStr<char> const, std::map<CStdStr<char>, CStdStr<char>, std::less<CStdStr<char> >, std::allocator<std::pair<CStdStr<char> const, CStdStr<char> > > > > > >::_M_insert_unique_(std::_Rb_tree_const_iterator<std::pair<CStdStr<char> const, std::map<CStdStr<char>, CStdStr<char>, std::less<CStdStr<char> >, std::allocator<std::pair<CStdStr<char> const, CStdStr<char> > > > > >, std::pair<CStdStr<char> const, std::map<CStdStr<char>, CStdStr<char>, std::less<CStdStr<char> >, std::allocator<std::pair<CStdStr<char> const, CStdStr<char> > > > > const&) ()
Thread 1 (Thread 2216):
#1 0x00000000007c95d6 in CButtonTranslator::MapRemote(TiXmlNode*, char const*) ()
#2 0x00000000007c9bc8 in CButtonTranslator::LoadLircMap(CStdStr<char> const&) ()
#3 0x00000000007ca8fd in CButtonTranslator::Load() ()
#4 0x00000000006de49e in CApplication::Create() ()
#5 0x0000000000907d85 in main ()
############# END STACK TRACE ###############
################# LOG FILE ##################
snip snip...
00:25:46 T:140717264468032 M:7301722112 INFO: Loading special://xbmc/system/keymaps/joystick.WiiRemote.xml
00:25:46 T:140717264468032 M:7301722112 INFO: Loading special://xbmc/system/keymaps/keyboard.xml
00:25:46 T:140717264468032 M:7301722112 INFO: Loading special://xbmc/system/keymaps/remote-back.xml
00:25:46 T:140717264468032 M:7301722112 ERROR: Window Translator: Can't find window scriptsdebuginfo
00:25:46 T:140717264468032 M:7301603328 INFO: Loading special://xbmc/system/keymaps/remote.xml
00:25:46 T:140717264468032 M:7301603328 INFO: Loading special://masterprofile/keymaps/Lircmap.xml
00:25:46 T:140717264468032 M:7301603328 ERROR: special://masterprofile/keymaps/Lircmap.xml Doesn't contain <keymap>
00:25:46 T:140717264468032 M:7301603328 INFO: Loading special://profile/keymaps/Lircmap.xml
00:25:46 T:140717264468032 M:7301603328 ERROR: special://profile/keymaps/Lircmap.xml Doesn't contain <keymap>
00:25:46 T:140717264468032 M:7301603328 INFO: Loading special://xbmc/system/Lircmap.xml
00:25:46 T:140717264468032 M:7301603328 INFO: * Adding remote mapping for device 'mceusb'
00:25:46 T:140717264468032 M:7301603328 INFO: * Adding remote mapping for device 'XboxDVDDongle'
00:25:46 T:140717264468032 M:7301603328 INFO: * Adding remote mapping for device 'Microsoft_Xbox'
00:25:46 T:140717264468032 M:7301603328 INFO: * Adding remote mapping for device 'PinnacleSysPCTVRemote'
00:25:46 T:140717264468032 M:7301603328 INFO: * Adding remote mapping for device 'anysee'
00:25:46 T:140717264468032 M:7301603328 INFO: * Adding remote mapping for device 'iMON-PAD'
00:25:46 T:140717264468032 M:7301603328 INFO: * Adding remote mapping for device 'Antec_Veris_RM200'
00:25:46 T:140717264468032 M:7301603328 INFO: * Adding remote mapping for device 'MCE_via_iMON'
00:25:46 T:140717264468032 M:7301603328 INFO: * Adding remote mapping for device 'TwinHanRemote'
00:25:46 T:140717264468032 M:7301603328 INFO: * Adding remote mapping for device 'linux-input-layer'
00:25:46 T:140717264468032 M:7301603328 INFO: * Linking remote mapping for 'linux-input-layer' to 'cx23885_remote'
00:25:46 T:140717264468032 M:7301603328 INFO: * Linking remote mapping for 'linux-input-layer' to 'devinput'
00:25:46 T:140717264468032 M:7301603328 INFO: Loading special://profile/Lircmap.xml
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
