Full Version: HP MediaConnect Universal Remote
I purchased this remote online: http://shop.accessory4you.com/05-chanpin...sp?id=4059
However i can not find a document on how to setup the TV/CBL/DVD/AUX functions of the remote.
Does anyone have a link or know how to setup these functions?
HP MediaSmart Connect Remote - Autotune for TV/CBL/DVD/AUX modes
HP P/N: 5189-3685
Found the answer:
Open this PDF: http://h10032.www1.hp.com/ctg/Manual/c01469387.pdf
Important information is on: Pages 50 - 66
The basics for the auto program feature is:
1) Press the 'Device' key until you select the device you would like to program. Then wait until the device light goes out.
2) Press and hold the 'Device' key for 5 seconds, it should become solid.
3) Enter '8, 8, 8, 8' The light will blink and then go out.
4) Press the 'Power' button.
If the device turns off, press the 'OK' button to lock the code in.
If the device doesnt turn off, slow press the 'power' button waiting about a second between presses to see if the device goes off, if it doesnt continue pressing. Once it does turn off, press the 'OK' button to lock in the code.
If you press pass the proper code you will need to do the steps over, and it will likely take longer, i found that i had to press it over 150x before my LG TV turned off.
Hi!
I've bought this remote with USB receiver on Ebay. If I program the other device it works well, but it don't work on the pc.
The situation is:
1) The usb Receiver is installed on Win7 as "Microsoft Infrared eHome receiver"
2) The remote works with other programmable devices.
Could you help me?
Hp mediasmart Connect can't be programmed.
you can select anyone of the other 4 device to be used as mce remote. The mce remote code is 5018 or 5020.
I have a problem with this device. I got one from eBay and it came with the "hp media center" receiver... eHome USB or something. The receiver is installed ok, but I think the controlller isn't set up for its own receiver. What device should I use in the controller to use it with it's receiver? I have to setup a device? I have to use a four digit code? What code?
Thank you for any help, guys!
The remote is hard coded to the HP MediaSmart Connect Box for the first device. The other 4 devices are the universal (programmable) part. If you really want to use first device, could probably use LIRC in Linux to map the keys. Doesn't seem to have a JP1 6 pin port, for programming it from a PC. But using CBL device and the 5018 code does work. Just have to pretend the first device option doesn't exist.
Just used the 5018 code and now it's working. Couldn't find this code anywhere... what a hell.
Thanks BigB42078!
You CAN use Media Smart Connet mode with Microsoft Infrared eHome receiver without programming.
Just modify Windows registry like I did below and restart system.
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\HidIr\Remotes\745a17a0-74d3-11d0-b6fe-00a0c90f57da]
"CodeSetNum0"=dword:00000008
"CodeSetNum1"=dword:00000000
"CodeSetNum2"=dword:00000000
"CodeSetNum3"=dword:00000000
"CodeSetNumMask"=dword:00005000
"CodeMatchMask"=dword:ffff0f00
"CodeMatchValue"=dword:80110200
Etharr, can you provide further information on your registry changes that allow the use of a MediaSmart Connect (or is it really a MediaSmart TV) without programming codes?
Thank You
I realise this is thread necromancy, but this is one of only two places on the Internet that I found hints on how to get a HP Mediasmart TV remote working with an RC6 MCE eHome IR USB receiver.
The "CodeMatchValue" and "CodeSetNumMask" seem critical to make this work.  The "CodeSetNum<x>" values didn't appear to affect anything when set to 8,0,0,0 or the stock 1,2,3,4.
I used the documentation at http://xbmccustomregis.sourceforge.net/remapping.html and generated a full range mapping table to identify the buttons in use, and to map them to custom keys.  Every single button works and are mappable.  This is what I ended up with, posting it here for posterity (and maybe help someone else trying to use this remote, mine is HP P/N: 5189-3683 (MediasmartTV, CBL, DVD, AVR, AUX), with a MCE receiver):
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\HidIr\Remotes\745a17a0-74d3-11d0-b6fe-00a0c90f57da]
"RemoteName"="RC6 based MCE remote"
"EnableDebounce"=dword:00000001
"EnableVendorPassThrough"=dword:00000001
"DecoderID"=dword:00000001
"CodeSetID"=dword:00000000
"CodeBitLen"=dword:00000020
"CodeSetNum0"=dword:00000001
"CodeSetNum1"=dword:00000002
"CodeSetNum2"=dword:00000003
"CodeSetNum3"=dword:00000004
"CodeSetNumShiftBits"=dword:0000000c
"DataMask"=dword:000000ff
"DataShiftBits"=dword:00000000
"ReportLength"=dword:00000003
"ReportDescriptor"=hex:05,0c,09,01,a1,01,85,01,19,00,2a,3c,02,15,00,26,3c,02,\
  95,01,75,10,81,00,c0,06,bc,ff,09,88,a1,01,85,02,19,01,29,ff,15,00,25,01,95,\
  01,75,08,81,00,c0,05,01,09,80,a1,01,85,03,19,01,29,ff,15,01,25,ff,95,01,75,\
  08,81,00,c0,05,01,09,06,a1,01,85,04,05,07,19,e0,29,e8,75,01,95,08,81,02,19,\
  00,29,90,26,ff,00,75,08,95,01,81,00,c0
"ReportMappingTable"=hex:\
  00,00,00,00,04,00,27,\ ; [0]                  -> 0
  01,00,00,00,04,00,1e,\ ; [1]                  -> 1
  02,00,00,00,04,00,1f,\ ; [2]                  -> 2
  03,00,00,00,04,00,20,\ ; [3]                  -> 3
  04,00,00,00,04,00,21,\ ; [4]                  -> 4
  05,00,00,00,04,00,22,\ ; [5]                  -> 5
  06,00,00,00,04,00,23,\ ; [6]                  -> 6
  07,00,00,00,04,00,24,\ ; [7]                  -> 7
  08,00,00,00,04,00,25,\ ; [8]                  -> 8
  09,00,00,00,04,00,26,\ ; [9]                  -> 9
  0a,00,00,00,04,00,0f,\ ; [Last]               -> L
  0b,00,00,00,04,00,10,\ ; [Media]              -> M
  0c,00,00,00,04,00,16,\ ; [Power]              -> S
  0e,00,00,00,04,00,04,\ ;
  0d,00,00,00,04,00,41,\ ; [Mute]               -> F8
  0e,00,00,00,04,00,07,\ ;
  0f,00,00,00,04,00,08,\ ;
  10,00,00,00,04,00,43,\ ; [Vol+]               -> F10
  11,00,00,00,04,00,42,\ ; [Vol-]               -> F9
  12,00,00,00,04,00,0b,\ ;
  13,00,00,00,04,00,0c,\ ;
  14,00,00,00,04,00,0d,\ ;
  15,00,00,00,04,00,0e,\ ;
  16,00,00,00,04,00,0f,\ ;
  17,00,00,00,04,00,1f,\ ;
  18,00,00,00,04,00,11,\ ;
  19,00,00,00,04,00,1e,\ ;
  1a,00,00,00,04,00,13,\ ;
  1b,00,00,00,04,00,52,\ ;
  1c,00,00,00,04,00,51,\ ;
  1d,00,00,00,04,00,50,\ ;
  1e,00,00,00,04,00,4b,\ ; [Ch+]                -> PageUp
  1f,00,00,00,04,00,4e,\ ; [Ch-]                -> PageDn
  20,00,00,00,04,01,09,\ ; [Skip >|]            -> Ctrl-F
  21,00,00,00,04,01,05,\ ; [Replay |<]          -> Ctrl-B
  22,00,00,00,04,00,1b,\ ;
  23,00,00,00,04,00,1c,\ ;
  24,00,00,00,04,00,1d,\ ;
  25,00,00,00,04,00,1e,\ ;
  26,00,00,00,04,00,1f,\ ;
  27,00,00,00,04,00,1e,\ ;
  28,00,00,00,04,03,09,\ ; [Fast Forward >>]    -> Ctrl-Shift-F
  29,00,00,00,04,03,05,\ ; [Rewind <<]          -> Ctrl-Shift-B
  2a,00,00,00,04,00,21,\ ;
  2b,00,00,00,04,00,04,\ ;
  2c,00,00,00,04,03,13,\ ; [Play]               -> Ctrl-Shift-P
  2d,00,00,00,04,00,1e,\ ;
  2e,00,00,00,04,00,24,\ ;
  2f,00,00,00,04,00,25,\ ;
  30,00,00,00,04,01,13,\ ; [Pause]              -> Ctrl-P
  31,00,00,00,04,03,16,\ ; [Stop]               -> Ctrl-Shift-S
  32,00,00,00,04,00,26,\ ;
  33,00,00,00,04,00,27,\ ;
  34,00,00,00,04,01,04,\ ;
  35,00,00,00,04,00,04,\ ;
  36,00,00,00,04,01,1f,\ ;
  37,00,00,00,04,00,14,\ ; [Record]             -> Q
  38,00,00,00,04,01,18,\ ;
  39,00,00,00,04,01,19,\ ;
  3a,00,00,00,04,01,1a,\ ;
  3b,00,00,00,04,01,1b,\ ;
  3c,00,00,00,04,01,1c,\ ;
  3d,00,00,00,04,01,1d,\ ;
  3e,00,00,00,04,01,1e,\ ;
  3f,00,00,00,04,01,1f,\ ;
  40,00,00,00,04,00,1f,\ ;
  41,00,00,00,04,01,21,\ ;
  42,00,00,00,04,00,05,\ ;
  43,00,00,00,04,00,1f,\ ;
  44,00,00,00,04,01,24,\ ;
  45,00,00,00,04,01,25,\ ;
  46,00,00,00,04,01,26,\ ;
  47,00,00,00,04,01,27,\ ;
  48,00,00,00,04,02,04,\ ;
  49,00,00,00,04,02,05,\ ;
  4a,00,00,00,04,00,05,\ ;
  4b,00,00,00,04,02,07,\ ;
  4c,00,00,00,04,02,08,\ ;
  4d,00,00,00,04,02,09,\ ;
  4e,00,00,00,04,02,0a,\ ;
  4f,00,00,00,04,02,0b,\ ;
  50,00,00,00,04,02,0c,\ ;
  51,00,00,00,04,02,0d,\ ;
  52,00,00,00,04,02,0e,\ ;
  53,00,00,00,04,02,0f,\ ;
  54,00,00,00,04,00,3f,\ ; [Settings]           -> F6
  55,00,00,00,04,00,2a,\ ; [Back]               -> Backspace
  56,00,00,00,04,00,29,\ ; [Clear]              -> Escape
  57,00,00,00,04,02,13,\ ;
  58,00,00,00,04,00,52,\ ; [Up]                 -> Up
  59,00,00,00,04,00,51,\ ; [Down]               -> Down
  5a,00,00,00,04,00,50,\ ; [Left]               -> Left
  5b,00,00,00,04,00,4f,\ ; [Right]              -> Right
  5c,00,00,00,04,00,28,\ ; [OK]                 -> Enter
  5d,00,00,00,04,02,19,\ ;
  5e,00,00,00,04,02,1a,\ ;
  5f,00,00,00,04,02,1b,\ ;
  60,00,00,00,04,02,1c,\ ;
  61,00,00,00,04,02,1d,\ ;
  62,00,00,00,04,02,1e,\ ;
  63,00,00,00,04,02,1f,\ ;
  64,00,00,00,04,00,21,\ ;
  65,00,00,00,04,02,21,\ ;
  66,00,00,00,04,00,06,\ ;
  67,00,00,00,04,00,22,\ ;
  68,00,00,00,04,02,24,\ ;
  69,00,00,00,04,02,25,\ ;
  6a,00,00,00,04,02,26,\ ;
  6b,00,00,00,04,02,27,\ ;
  6c,00,00,00,04,03,04,\ ;
  6d,00,00,00,04,03,05,\ ;
  6e,00,00,00,04,00,07,\ ;
  6f,00,00,00,04,03,07,\ ;
  70,00,00,00,04,03,08,\ ;
  71,00,00,00,04,03,09,\ ;
  72,00,00,00,04,03,0a,\ ;
  73,00,00,00,04,03,0b,\ ;
  74,00,00,00,04,03,0c,\ ;
  75,00,00,00,04,03,0d,\ ;
  76,00,00,00,04,03,0e,\ ;
  77,00,00,00,04,03,0f,\ ;
  78,00,00,00,04,00,21,\ ;
  79,00,00,00,04,03,11,\ ;
  7a,00,00,00,04,00,23,\ ;
  7b,00,00,00,04,03,13,\ ;
  7c,00,00,00,04,03,14,\ ;
  7d,00,00,00,04,00,05,\ ;
  7e,00,00,00,04,00,24,\ ;
  7f,00,00,00,04,03,17,\ ;
  80,00,00,00,04,03,18,\ ;
  81,00,00,00,04,01,07,\ ; [Info]               -> Ctrl-D
  83,00,00,00,04,03,1b,\ ;
  84,00,00,00,04,03,1c,\ ;
  85,00,00,00,04,03,1d,\ ;
  86,00,00,00,04,03,1e,\ ;
  87,00,00,00,04,03,1f,\ ;
  88,00,00,00,04,00,25,\ ;
  89,00,00,00,04,03,21,\ ;
  8a,00,00,00,04,00,06,\ ;
  8b,00,00,00,04,05,16,\ ; [Source]             -> Ctrl-Alt-S
  8c,00,00,00,04,00,21,\ ;
  8d,00,00,00,04,03,25,\ ;
  8e,00,00,00,04,03,26,\ ;
  8f,00,00,00,04,03,27,\ ;
  90,00,00,00,04,04,04,\ ;
  91,00,00,00,04,04,05,\ ;
  92,00,00,00,04,00,17,\ ; [Live TV]            -> T
  93,00,00,00,04,04,07,\ ;
  94,00,00,00,04,04,08,\ ;
  95,00,00,00,04,04,09,\ ;
  96,00,00,00,04,04,0a,\ ;
  97,00,00,00,04,04,0b,\ ;
  98,00,00,00,04,04,0c,\ ;
  99,00,00,00,04,04,0d,\ ;
  9a,00,00,00,04,04,0e,\ ;
  9b,00,00,00,04,04,0f,\ ;
  9c,00,00,00,04,00,07,\ ;
  9d,00,00,00,04,04,11,\ ;
  9e,00,00,00,04,04,12,\ ;
  9f,00,00,00,04,07,16,\ ; [Last Source]        -> Ctrl-Alt-Shift-S
  a0,00,00,00,04,00,12,\ ; [Recorded TV]        -> O
  a1,00,00,00,04,05,28,\ ; [Windows/MCE]        -> Ctrl-Alt-Enter
  a2,00,00,00,04,03,20,\ ; [#]                  -> Ctrl-Shift-3
  a3,00,00,00,04,00,40,\ ; [Screen]             -> F7
  a4,00,00,00,04,04,18,\ ;
  a5,00,00,00,04,04,19,\ ;
  a6,00,00,00,04,04,1a,\ ;
  a7,00,00,00,04,04,1b,\ ;
  a8,00,00,00,04,01,16,\ ; [Sleep]              -> Ctrl-S
  a9,00,00,00,04,04,1d,\ ;
  aa,00,00,00,04,04,1e,\ ;
  ab,00,00,00,04,04,1f,\ ;
  ac,00,00,00,04,03,25,\ ; [- *]                -> Ctrl-Shift-8
  ad,00,00,00,04,03,25,\ ;
  ae,00,00,00,04,00,09,\ ;
  af,00,00,00,04,00,0a,\ ;
  b0,00,00,00,04,04,24,\ ;
  b1,00,00,00,04,04,25,\ ;
  b2,00,00,00,04,04,26,\ ;
  b3,00,00,00,04,04,27,\ ;
  b4,00,00,00,04,05,04,\ ;
  b5,00,00,00,04,05,05,\ ;
  b6,00,00,00,04,00,09,\ ;
  b7,00,00,00,04,05,07,\ ;
  b8,00,00,00,04,05,08,\ ;
  b9,00,00,00,04,05,09,\ ;
  ba,00,00,00,04,05,0a,\ ;
  bb,00,00,00,04,05,0b,\ ;
  bc,00,00,00,04,05,0c,\ ;
  bd,00,00,00,04,05,0d,\ ;
  be,00,00,00,04,05,0e,\ ;
  bf,00,00,00,04,05,0f,\ ;
  c0,00,00,00,04,00,05,\ ;
  c1,00,00,00,04,05,11,\ ;
  c2,00,00,00,04,05,12,\ ;
  c3,00,00,00,04,05,13,\ ;
  c4,00,00,00,04,05,14,\ ;
  c5,00,00,00,04,00,07,\ ;
  c6,00,00,00,04,00,24,\ ;
  c7,00,00,00,04,05,17,\ ;
  c8,00,00,00,04,05,18,\ ;
  c9,00,00,00,04,05,19,\ ;
  ca,00,00,00,04,05,1a,\ ;
  cb,00,00,00,04,05,1b,\ ;
  cc,00,00,00,04,00,06,\ ; [Guide]              -> C
  cd,00,00,00,04,05,1d,\ ;
  ce,00,00,00,04,05,1e,\ ;
  cf,00,00,00,04,05,1f,\ ;
  d0,00,00,00,04,00,26,\ ;
  d1,00,00,00,04,05,21,\ ;
  d2,00,00,00,04,00,0b,\ ;
  d3,00,00,00,04,00,06,\ ;
  d4,00,00,00,04,05,24,\ ;
  d5,00,00,00,04,05,25,\ ;
  d6,00,00,00,04,05,26,\ ;
  d7,00,00,00,04,05,27,\ ;
  d8,00,00,00,04,06,04,\ ;
  d9,00,00,00,04,06,05,\ ;
  da,00,00,00,04,00,0a,\ ;
  db,00,00,00,04,06,07,\ ;
  dc,00,00,00,04,06,08,\ ;
  dd,00,00,00,04,06,09,\ ;
  de,00,00,00,04,06,0a,\ ;
  df,00,00,00,04,06,0b,\ ;
  e0,00,00,00,04,06,0c,\ ;
  e1,00,00,00,04,00,1d,\ ; [Enter]              -> Z
  e2,00,00,00,04,06,0e,\ ;
  e3,00,00,00,04,06,0f,\ ;
  e4,00,00,00,04,00,2b,\ ; [CC/Red]             -> Tab
  e5,00,00,00,04,03,0f,\ ; [Aspect/Green]       -> Ctrl-Shift-L
  e6,00,00,00,04,01,1c,\ ; [SAP/Yellow]         -> Ctrl-Y
  e7,00,00,00,04,00,1a,\ ; [Fav/Blue]           -> W
  e8,00,00,00,04,06,14,\ ;
  e9,00,00,00,04,00,08,\ ;
  ea,00,00,00,04,00,25,\ ;
  eb,00,00,00,04,06,17,\ ;
  ec,00,00,00,04,06,18,\ ;
  ed,00,00,00,04,06,19,\ ;
  ee,00,00,00,04,06,1a,\ ;
  ef,00,00,00,04,06,1b,\ ;
  f0,00,00,00,04,06,1c,\ ;
  f1,00,00,00,04,06,1d,\ ;
  f2,00,00,00,04,06,1e,\ ;
  f3,00,00,00,04,06,1f,\ ;
  f4,00,00,00,04,00,27,\ ;
  f5,00,00,00,04,06,21,\ ;
  f6,00,00,00,04,00,0c,\ ;
  f7,00,00,00,04,00,24,\ ;
  f8,00,00,00,04,06,24,\ ;
  f9,00,00,00,04,06,25,\ ;
  fa,00,00,00,04,06,26,\ ;
  fb,00,00,00,04,06,27,\ ;
  fc,00,00,00,04,07,04,\ ;
  fd,00,00,00,04,07,05,\ ;
  fe,00,00,00,04,00,0b,\ ;
  ff,00,00,00,04,07,07,\ ;
