Full Version: Using banners as posters in TV view
Now ( having fully read the FAQ this time Blush ), I have another bug/question.
When I have 'Enable Posters' selected, it keeps trying to cram banners into poster boxes with terrible results for aspect ratio.
The banners/posters are the ones picked by the default TVDB scraper ( I set it to 'Prefer Posters' and re-ran a few, but it didn't appear to make any difference ), and I have taken a look at some of the affected series and confirmed that they have downloaded both a banner and a poster, it's just incorrectly trying to use the banner.
Going to series info and then picking a poster from 'Get Thumbs' works fine, but is pretty tedious.
Shows that used the ANIDB scraper look fine, although as far as I can tell, that's only because that script only downloads posters, not banners.
velk Wrote:Now ( having fully read the FAQ this time Blush ), I have another bug/question.
if you have banners, then why select this option?
only select it if you have posters for tv series.
velk Wrote:The banners/posters are the ones picked by the default TVDB scraper ( I set it to 'Prefer Posters' and re-ran a few, but it didn't appear to make any difference ), and I have taken a look at some of the affected series and confirmed that they have downloaded both a banner and a poster, it's just incorrectly trying to use the banner.
that's all handled by xbmc / scrapers, so outside of the scope of the skin.
there's nothing i can do about it.
I had the same problem.
I solved it by first setting the folder content to “None” and then updating when asked. The update removed the banners/posters. Then I checked the “Prefer Posters” button under the TVDB scrapper settings and once again set the type of the folder to TV with the TVDB scrapper. After that I just updated the library and there were my posters.
