depends on which view you're using:
fanart view - press left
slide view - press up
ronie Wrote:depends on which view you're using:
But in fanart view if I press left I go to the menu where you select sorting, activate library, etc.
ashlar Wrote:But in fanart view if I press left I go to the menu where you select sorting, activate library, etc.
weird...anyone else having this problem?
Left once gives me trailer twice gives me menu
>>X<<' Wrote:Left once gives me trailer twice gives me menu
cheers!
exactly how it's supposed to work.
Are you using a remote? Maybe your system is registering a double press?
One press for me too. I changes the color to blue. Two left presses gives me menu.
