Full Version: AEON 64 and latest dharma not working
Hi there,
I've got a problem with dharma not reconizing aeon folder in any way as a skin. I've dropped the folder inside addons and inside skins, it doesn't make any difference. I noticed the confluence skin inside addons has an addon.xml on its root instead of skin.xml like aeon has.
I'm using windows 7 so I found that XBMC keeps files on the roaming folder inside my user data, well even copying the skin over there didin't make any difference
any suggestions please?
It sounds like you are downloading an older version. Try here and saving the files to addons/skin.aeon65. That folder should be the contents of the zip you download, i.e, addon.xll 720p, colors, extras, etc.
stoli Wrote:It sounds like you are downloading an older version. Try here and saving the files to addons/skin.aeon65. That folder should be the contents of the zip you download, i.e, addon.xll 720p, colors, extras, etc.
Thanks for this mate!
I'm downloading now
