Is there any way you can tell XBMC to remember each themes view settings once you have them set up? I hate having to switch the views around each time I change themes.
I wish this was possible too. Or at least only have to change one view for all the season in TV view, I have to change each show, then each season. It takes forever. Am I doing it wrong?
I like being able to customize the view for each "level" that you drill down to for TV shows, but I just wish I only had to set it once and it would be remembered if I change the theme and then change back to the theme I configured.
Thanks for posting that, I'll keep an eye on it too.
