Full Version: Resulotion problem
Hi!
I have problem with resolution on my XBMC 10.0
I use Xbmc live and have the following connection over HDMI
HTPC---->AV Receiver----->HDMI splitter---> TV 720P and Projector 1080p
The problem is that xbmc will not boot up in 1080p even if TV is off. If i disconnect HDMI from TV it boot up in 1080p. I cannot change resolution to higher because 720p is the highest when TV is connected.
How do i fix this so i can change manually to 1080 p when i use projector.
I'm having a somewhat similar problem. I would like to force my output to 720p, but it is only detecting 480p
older ati x800 is connected to tv via dvi
