K thanks figured it out but not working for me
did this (created xml and put in correct directory)
userdata/playercorefactory.xml
Still wont play next song automatically for me
anyone have another solution
Thanks all
UPDATE
BTW the cursor or menu does move down to the next song for me, but wont play it
OKAY it works had to set up via the left menu option I think shuffle
dominater01 Wrote:anyway you can make it so the playlists are in abc order cuz when you have 148 differnt playlists like me its hard to find what i want to listen to
also its hard to c song names sometimes is there anyway you could change it to track artist album insted of artist album track
You're talking only about the playlist names, right? I too would like to see these in alphabetical order, but only if the actual songs on the playlists remain in the order as originally defined. Since my playlists typically represent albums, I'd hate to have the songs play in alphabetical order rather than album order.
rbrohman Wrote:You're talking only about the playlist names, right? I too would like to see these in alphabetical order, but only if the actual songs on the playlists remain in the order as originally defined. Since my playlists typically represent albums, I'd hate to have the songs play in alphabetical order rather than album order.
just playlist names in alphabetical order not songs
the song ordor should stay the same tho
edit: oops i accidently double posted
On AppleTV2, i get the following script error (except the first run).
11:18:32 T:155783168 M:117964800 NOTICE: Response...
11:18:32 T:155783168 M:117964800 NOTICE: '{"header":{"hostname":"RHL060"},"result":"\\u0417\\u0434\\u0440\\u0430\\u0432\\u0441\\u0442\\u0432\\u0443\\u043b\\u0442\\u0435!, \\u043c\\u0438\\u0440."}'
11:18:32 T:155783168 M:117964800 ERROR: Error Type: <type 'exceptions.OSError'>
11:18:32 T:155783168 M:117964800 ERROR: Error Contents: (17, 'File exists', '/var/mobile/Library/Preferences/XBMC/userdata/addon_data/plugin.audio.groove/thumb')
11:18:32 T:155783168 M:117956608 ERROR: Traceback (most recent call last):
File "/var/mobile/Library/Preferences/XBMC/addons/plugin.audio.groove/default.py", line 386, in <module>
grooveshark = Groveshark();
File "/var/mobile/Library/Preferences/XBMC/addons/plugin.audio.groove/default.py", line 81, in __init__
os.makedirs(artDir)
File "/private/var/stash/Applications/XBMC.frappliance/Frameworks/usr/lib/python2.6/os.py", line 157, in makedirs
mkdir(name, mode)
OSError: (17, 'File exists', '/var/mobile/Library/Preferences/XBMC/userdata/addon_data/plugin.audio.groove/thumb')
11:18:33 T:144982016 M:118153216 ERROR: GetDirectory - Error getting plugin://plugin.audio.groove/?mode=4&name=Popular+songs&id=0
11:18:33 T:144982016 M:118153216 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.audio.groove/?mode=4&name=Popular+songs&id=0) failed
As a workaround, i must delete the thumb directory in /private/var/mobile/Library/Preferences/XBMC/userdata/addon_data/plugin.audio.groove/ manually after each time i use the 'select' button.
or
I had to comment out these lines
# if os.path.isdir(thumbDir) == False:
# artDir = xbmc.translatePath(thumbDir)
# os.makedirs(artDir)
# xbmc.log("Made " + artDir)
Muuh Wrote:As a workaround, i must delete the thumb directory in /private/var/mobile/Library/Preferences/XBMC/userdata/addon_data/plugin.audio.groove/ manually after each time i use the 'select' button.
This is the same problem that was reported earlier in this thread. Please try installing version 0.2.3:
http://sourceforge.net/projects/xbmc-gro...p/download
okay, 0.2.3 did also work here. Thanks!
Continuous playback doesn't work for me (as others have reported in this thread).
Added file playercorefactory.xml with
<playercorefactory>
<rules action="prepend">
<rule audio="true" player="audiodefaultplayer">
<rule filename="*grooveshark.com*" player="dvdplayer"/>
</rule>
</rules>
</playercorefactory>
Muuh Wrote:Continuous playback doesn't work for me (as others have reported in this thread)
As far as I can tell, the continuous playback problem only seems to affect Apple users. However, dallasnights reports getting it working with the shuffle option in the player OSD. See
http://forum.xbmc.org/showpost.php?p=699...stcount=76
It definitely works okay (for me) on the Linux version.
Also, I found this:
http://forum.xbmc.org/showpost.php?p=694...tcount=331
...which implies it is an XBMC (not an addon) bug. If you have >= r35433 and it is still a problem then perhaps try raising an XBMC Trac ticket.
Stephen.
I noticed, that when i select 'Popular'/'Katy Pery...', only this single song is played and no other song after this one.
When i go one level up and use the context menu for 'Popular' and select 'Play' there, all files are played each after another.
Perhaps you could add a menu item 'Play all' directly under 'Popular' (=each Category)? I think the expected behaviour of the user is, that you get continuous playback of all songs in that category without such an entry.
edit: sorry i accidently double posted
edit: sorry i double posted
i would like to request
a button for add selected item to playlist in the context menu and have it so we can name our playlist b4 we add it
like the script used to
that feature is kinda hard to explane but if you used to script hopefully you know what i mean
i would like to request all those features that the script had
save playlist as
add song to playlist
EDIT: i really hate my browser sorry for all posts i didnt notice them till after
dominater01 Wrote:i would like to request all those features that the script had
save playlist as
I know what you mean. There are some methods in the new API to do this but I cannot make them work. At most I can create a playlist and add one song only. Adding an array of songs doesn't seem to work
Anyway, if I get it working, I will include it in the next release.
