All is in the title
I know it soulds stupid but i did not find anywhere in the "System" option where to do that...
Might not be possible from teh graphic interface?
Thanks in advance
I think I have found a way...
Open
C:\Users\(your name)\AppData\Roaming\XBMC\userdata\guisettings.xml
Change the value true to false
<showsubtitles>true</showsubtitles>
Will let you know the result
Whwn you're playing a video press M to open the OSD. Select the second button in from the top left (you can use the arrow keys to navigate the OSD) to open the Audio and Subtitle Settings. Set the subtitle options there, then select the bottom option "Set as default for all movies".
JR
Many thanks for that!
Have already modified manually my config file (and it worked) but good to know how to do it for the next time!!
