Full Version: MCE Remote how to map ALT - F4
Hey guys i have been playing around with MCERemote addon but i cant seem to remap a key to ALT-F4.
Anybody have any ideas?
JimiW Wrote:Hey guys i have been playing around with MCERemote addon but i cant seem to remap a key to ALT-F4.
In the specific key field type alt-f4 save and then restart.
Cheers,
EG.
elitegamer360 Wrote:In the specific key field type alt-f4 save and then restart.
Cheers,
EG.
The settings screen doesn't warn you if you close it without saving. It's very easy to make your changes then press Back or Escape to return to the previous menu, and of course this doesn't save the changes.
I hasten to add I'm not responsible for coding the settings dialog :-)
JR
Thanks for the responses guys but i didnt really seem to get it working within XMBC. So i just edited the msremote.reg and changed the button i wanted to use to 04,00,00 or something and it worked like a charm!
jhsrennie Wrote:The settings screen doesn't warn you if you close it without saving. It's very easy to make your changes then press Back or Escape to return to the previous menu, and of course this doesn't save the changes.
JR
Yes, this is something I wanted to point out but I see you're already aware of it. Smile
