The subtitle button appears on the top menu while playing movie but it is kind of light gray and it does not work at all when clicked.
Any suggestions? I'm using dharma 10.0
Droidman86 Wrote:The subtitle button appears on the top menu while playing movie but it is kind of light gray and it does not work at all when clicked.
I think what you are talking about is the subtitles script, its specific to what skin you are using but when you enable it you need to navigate to identify its path.
go to Settings_> SKIN_> General_. in Global settings heading enter the script path.
For normal subs:
go to Settings_> Video _> Subtitles_. Then in the subtitle submenu navigate to where your subtitles are saved and press OK.
I'm currently using night skin.
Cheers,
EG.
