Ok so here's the problem, I have a few old Nickelodeon shows that have 2 episodes per show but thetvdb lists them as separate episodes for scraping but they are in the same file.
Any way to fix this besides manually changing the title in XBMC or editing the videos and splitting them?
Create your own nfo file for each show.
Darkm27 Wrote:Ok so here's the problem, I have a few old Nickelodeon shows that have 2 episodes per show but thetvdb lists them as separate episodes for scraping but they are in the same file.
Just name your files tvshowname.s01e01-e02.avi The scraper will then create two entries for each episode.
stoli Wrote:Just name your files tvshowname.s01e01-e02.avi The scraper will then create two entries for each episode.
This works out great! saved me a lot of time thank you!
mwkurt Wrote:BamBam,
Are you serious?
I have never used nfo so yes.
