Full Version: [LIVE] Revo R3610 + Dharma 10.0 Live. Sound problems
Hi all,
I have no HDMI sound using XBMC Live Final Dharma on my Acer Revo R3610. Did anybody have same problem?
Tried different things, such as unmute all devices in alsamixer or sound mixer in GUI. All is both output und pass-through is set to hdmi.
I created booting USB using XBMC Live CD on my PC. Also tried booting from UNetbootin created stick, it works too but Install doesn't work due to cdrom problems. Sound problems are the same.
I am also having problems with by ethernet connection, there is no connection at all with the stick created in XBMC. No eth0 device under /dev...
thanks in advance for any help.
i had the same problems with the sound.. eventually i needed to set the speaker configuration to 2.0, Audio to HDMI, Audio output to HDMI and audio pass through to HDMI. And ofcourse unmuting the muted channels with alsamixer.
http://forum.xbmc.org/showpost.php?p=667727&postcount=4
Solved using these instructions + unmuted all devices in alsamixer. Solution definitely needs to be pinned.
Network issues solved by editing interfaces file and adding eth1 interface.
