2010-12-24, 02:15
Okay guys I ran into lots of problems getting my Revo 1600 Ion machine to run well with Dharma. Here is my guide to getting everything working to allow hdmi audio/video to a TV. This guide will not help you if you need surround sound or run hdmi to an amp. Again **Use this guide if you only run hdmi to your tv**
Credit to thedalmeny, myrison and ngiardina - I've cannibalized all your threads for this guide.
This guide is based on using a bootable USB stick in order to install XBMC Live.
STEP 1 - REQUIRED DOWNLOADS
Download and Install WINSCP
here.
Download and Install Putty.
here.
Move putty.exe to Program Files (x86)/PuTTY/putty.exe
Download and Install unetbootin
here.
Download and Install HP Format Tool
here.
Download Latest XBMC Freak
here.
STEP 2 - FORMAT USB DRIVE
Open HP USB format tool, select to format the USB drive being used for the installation
Note: Do not use "Quick Format"
Note: Use FAT32
STEP 3 - PREP USB DRIVE
Once the USB drive has been formatted, you need to use unetbootin to make the bootable installation.
Open unetbootin
Select "Diskimage" and the XBMCLive ISO you have downloaded.
Select the USB drive being used for the installation and click "OK"
STEP 4 - XBMC INSTALLATION
Remove the USB drive used for the installation and place within one of the ports of the Acer Revo (Rear ports are preferred, as i presume they provide more power to any connected USB device)
When Acer splash screen displays, hit "DEL" to enter the BIOS setup.
Select "Advanced bios features" - setting the Acer Revo to boot from the USB drive first.
Save changes and exit the BIOS.
The Acer Revo should now boot from the USB stick and present you with some options, select the following option:
"Install XBMCLive"
Follow the prompts and when asked, select to use the entire drive for the installation (Do not use LVM).
Let the installation complete, following the prompts.
Once installation has complete, enter the BIOS once again and set the HDD as the first boot device.
Your Acer Revo should now boot into XBMC
STEP 5 - CONFIGURATION
Once XBMC has loaded, select the "Settings" options.
Goto Video and Playback and enable the following options:
Render Method: Audo Detect
Allow Hardware Acceleration (VDPAU): Enable
Adjust display refresh rate to match video: Enable
Sync playback to display: Enable
VDPAU Studio Level Color Conversion: Enable
A/V Sync Method: Video Clock, Drop/Dupe audio
Goto Audio Output settings and ebale the following options (This is purely based on my setup, change speaker configuration and receiver options in line with your own)
Audio Output: Analog
Speaker Configuration: 2.0
Boost Volumn Level On Downmix: Enable
Dolby Digital (AC3) Capable Receiver: Disabled
DTS Capable Receiver: Disabled
Audio Output Device: Defaults
Passthrough Output Device: Iec958
STEP 6 - LOG INTO THE REVO VIA PUTTY
Goto your PC and execute the previously installed WinSCP, using the IP address of the Acer Revo and username and password configured at installation. Log into the Revo.
Once loaded, select the following menu path to launch putty:
Commands > Open In Putty
At this stage you'll be asked once again for the password.
STEP 7 - UPDATE NVIDIA DRIVERS
Download the latest Nvidia drivers by performing the following command:
Kill x display by performing the following command:
It will ask for your password, enter it, and press enter.
Remove existing Nvidia drivers by performing the following command:
Install the new nvidia drivers by performing the following command:
The nvidia installer will start, make sure to say yes to creating a new configuration file.
STEP 8 - DISPLAY SETTINGS - 1080p / 23.97hz
Update the display settings by performing the following command:
STEP 9 - AUDIO SETTINGS
Update the audio settings (This will fix menu / audio issues which the 1600 has experienced for many):
Perform the following command:
A text editor will be shown.
Type everything as below:
Press CTRL + X and follow the prompts to exit and save the changes
STEP 10 - PERFORMANCE IMPROVEMENT
Using an additional setting can increase the performance when viewing fanart:
By adding another line, you'll want the file to look like this (The <useddfanart> line has to be added).
Select CTRL + X and follow the prompts to exit and save the changes
STEP 11 - REBOOT - YOUR DONE
The Acer Revo should now reboot, fully configured to work with XBMC Live.
here.
here.
here.
here.
here.
Note: Use FAT32
Open unetbootin
"Install XBMCLive"
sudo add-apt-repository ppa:ubuntu-x-swat/x-updates
sudo apt-get update
sudo pkill x
sudo apt-get --purge remove nvidia-*.
sudo pkill x
sudo apt-get install nvidia-current nvidia-current-modaliases nvidia-settings
sudo wget http://pastebin.com/download.php?i=6K3XjdUS -O /etc/X11/xorg.conf
sudo nano /etc/asound.conf
pcm.!default {
type plug
slave {
pcm “hw:0,3”
rate 48000
nano /home/xbmc/.xbmc/userdata/advancedsettings.xml
<advancedsettings>
<network>
<disableipv6>true</disableipv6>
</network>
<gputempcommand>echo "$(nvidia-settings -c :0 -tq GPUCoreTemp) C"</gputempcommand>
<useddsfanart>true</useddsfanart>
</advancedsettings>
sudo reboot now
