2010-12-24, 03:16
Hello,
I've got 2 annoying problems right now that I'm not able to solve. After looking around in the forum, nothing has worked so far. I've got an Acer Revo 3610 and it's updated to Darma latest Live release installed on it. Let's start with the first one:
1. The remote
I just bought a MCE remote "AVS Gear HA-IR01SV". I read from this page:
http://wiki.xbmc.org/index.php?title=Rem...ol_Reviews
that it should work "out of the box". It does not in my case.
So, when I plug it into my win7 computer, the light stays off and only flashes when I press a button. On my Live version, the light stays red all the time. (Should probably behave the same I imagine)
I did a "lsusb"
Maybe the "TopSeed Technology Corp" is not included in some lircd config files?
I also tried to reconfigure it:
And it doesn't do much.
I also checked if the IR receiver was detected:
So, if someone has some other tips. I would be happy to try.
--- EDIT ---
after reading the help of lircd, I just found out that there is a verbose mode. So, it seems that the kernel module isn't loading. I have no idea what it means...
--- EDIT #2 ---
It seems like that the device:
/dev/lirc0
is not listed. That's probably why LIRC isn't working properly. Any idea? Stopping for tonight investigating this annoying problem.
2. The Key configs
I don't know if it has anything to do with the first one, but I've been trying to setup some key on my keyboard and it doesn't work.
I've followed this:
http://wiki.xbmc.org/index.php?title=Keymap.xml
and it looks like my xml file is completely ignored.
I've tried to change the global one as well, and it's the same thing, ignore...
Thanks in advance.
1. The remote
I did a "lsusb"
~$ lsusb
Bus 002 Device 004: ID 04f2:0402 Chicony Electronics Co., Ltd
[b]Bus 002 Device 003: ID 1784:0011 TopSeed Technology Corp.[/b] <-- this one seems to be the IR module detected.
Bus 002 Device 002: ID 046d:c058 Logitech, Inc.
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 003: ID 1058:1110 Western Digital Technologies, Inc.
Bus 001 Device 004: ID 1058:1111 Western Digital Technologies, Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
~$ sudo dpkg-reconfigure lirc
~$ tail /var/log/syslog
Dec 23 20:17:48 XBMCLive kernel: [ 1524.368056] usb 2-4: new full speed USB device using ohci_hcd and address 5
Dec 23 20:17:48 XBMCLive kernel: [ 1524.581571] usb 2-4: configuration #1 chosen from 1 choice
Dec 23 20:20:21 XBMCLive lircd-0.8.6[1869]: caught signal
Dec 23 20:20:21 XBMCLive kernel: [ 1677.955666] usbcore: deregistering interface driver lirc_mceusb
Dec 23 20:20:25 XBMCLive kernel: [ 1681.473792] lirc_dev: IR Remote Control driver registered, major 61
Dec 23 20:20:25 XBMCLive kernel: [ 1681.482718] lirc_mceusb: Windows Media Center Edition USB IR Transceiver driver for LIRC 1.90
Dec 23 20:20:25 XBMCLive kernel: [ 1681.482728] lirc_mceusb: Daniel Melander <[email protected]>, Martin Blatter <[email protected]>, Dan Conti <[email protected]>
Dec 23 20:20:25 XBMCLive kernel: [ 1681.482810] usbcore: registered new interface driver lirc_mceusb
Dec 23 20:20:25 XBMCLive lircd-0.8.6[2116]: lircd(default) ready, using /var/run/lirc/lircd
~$ dmesg | grep -i usb
~$ lircd -v
lircd 0.8.6
--- EDIT ---
sudo /etc/init.d/lirc restart verbose
* Stopping remote control daemon(s): LIRC [ OK ]
* Loading LIRC modules [ OK ]
* Unable to load LIRC kernel modules. Verify your
* selected kernel modules in /etc/lirc/hardware.conf
--- EDIT #2 ---
/dev/lirc0
2. The Key configs
I've followed this:
~/.xbmc/userdata/keymaps/keyboard.xml
Thanks in advance.
