Full Version: [LINUX] SPDIF not working XBMC 10
Well waited for a long time for you guys to fix the problem most people with SPDIF are having with XBMC.
I have my computer with Ubuntu connected to my stereo with a a Optical SPDIF, ever since Pulse audio got intruduced to Ubuntu SPDIF has kinda been broken, but most programs like VLC and SMplayer has managed to go around it, SMplayer uses ALSA instead which works fine, easy to set up.
But XBMC still has no easy overide to ALSA, only way is to set the sound card to analog in sound settings in Ubuntu to get any sound in XBMC. But in doing that Ubuntu mutes the sound every time I reboot and I have to unmute all channels every time its really anoying, not to mention not getting any sound from browser and other things that has to use Pulse audio.
Please make it easy to force Alsa in XBMC to.
I guess no one has any easy fix to this? So its up to the xbmc team?
scirocco Wrote:I guess no one has any easy fix to this? So its up to the xbmc team?
I've found one on the internet..
6 steps.
  1. [If you have no sound yet] After having Ubuntu installed, go to the terminal, enter alsamixer and through F6 select the correct device. Then reboot
  2. Install the Alsa libraries
  3. Open the Pulse default Sound Preferences
  4. Click the Hardware tab
  5. Choose Analog Stereo Duplex profile
  6. In every application that supports hardware configuration, set sound output to IEC985 or similar
Step 6 is for me (settings - system - Audio output):
Audio output = Optical/Coax
Speaker Configuration = 5.1
Audio output device = alsa
Passthrough output device = iec958
For me this worked and XBMC is playing movies in 5.1 surround through SPDIF
Hopes this works out for you guys!
so remove pulse audio.
I have no problems with my spdif out.
darkscout Wrote:so remove pulse audio.
removing pulseaudio didn't solve a thing.. still had only stereo.. I want 5.1!
The steps written above fixed it for me!
Jarcol Wrote:I've found one on the internet..
6 steps.
I had the same problem. Your solution solve my problem. Big Grin
Thanks,
Max
