2010-12-26, 17:59
System info: XBMC 10.0 installed to HD from live disc
Remote: AVS Gear HA-IR01SV Infrared Certified MCE VISTA Remote Control (http://www.newegg.com/Product/Product.as...6880121001)
Mobo: Biostar G41D3G LGA 775 chipset
Video: PCIe Nvidia 7300LE
Out of the box remote works perfect, and power button puts the computer to sleeep. It does not wake it up, however. Wake from USB is enabled in the BIOS.
In /proc/acpi/wakeup I have:
Device S-state Status Sysfs node
P0P2 S4 disabled pci:0000:00:01.0
P0P3 S4 disabled
P0P1 S4 disabled pci:0000:00:1e.0
UAR1 S1 disabled pnp:00:06
USB0 S4 disabled pci:0000:00:1d.0
USB1 S4 disabled pci:0000:00:1d.1
USB2 S4 disabled pci:0000:00:1d.2
USB3 S4 disabled pci:0000:00:1d.3
EUSB S4 disabled pci:0000:00:1d.7
MC97 S4 disabled
P0P4 S4 disabled pci:0000:00:1c.0
P0P5 S4 disabled pci:0000:00:1c.1
P0P6 S4 disabled
P0P7 S4 disabled
P0P8 S4 disabled
P0P9 S4 disabled
PWRB S1 *enabled
If enable USB0 or USB2 (via echo to the /proc/acpi/wakeup file) then use the power button on the remote, the PC immediately wakes up after suspending (without any input from the remote or KB/Mouse). Enabling any other device the computer will go to sleep and require the power button to wake back up.
I've scoured google and spent hours banging around, going so far as to modify the "power" files in /sys/devices, but the result there seems to be the same as when I just modify /proc/acpi/wakeup.
Another interesting note, is whent he system is asleep the IR receiver does not light up when I hit any buttons (maybe it's not getting power?). Although I ready a post somewhere where someone else says there's doesn't light up either whne asleep, but remote still wakes up their system.
Anyone have any ideas?
P0P3 S4 disabled
MC97 S4 disabled
P0P6 S4 disabled
P0P7 S4 disabled
P0P8 S4 disabled
P0P9 S4 disabled
PWRB S1 *enabled
