sho Wrote:I fell for this one myself, "path is" is absolute. If there is no media file in that exact folder, it will have no results. Thus "path contains" or "starts with" is required.
Are that makes sense
BigO
Did you figure it out yet as I remembered I had fraps on one of my systems so did you a video as I'm bored
I added it to the sub menu but your get the idea not the greatest quality but ok as I didn't want to wait around ages for the upload to finish
http://www.youtube.com/watch?v=fld5556YpeQ
I think i see what i did wrong now, i didnt add the favorite under the "movie" section like you did. Im going to try again when i get home and see how it pans out.
BigO Wrote:I think i see what i did wrong now, i didnt add the favorite under the "movie" section like you did. Im going to try again when i get home and see how it pans out.
You can either add it under the movie section or under the main menu or both. It works any way you do it.
clubwerks Wrote:You can either add it under the movie section or under the main menu or both. It works any way you do it.
I think he might be referring to adding the playlist created to favorites first which of course you must do
>>X<< Wrote:Are that makes sense
@BigO
Many thank for the video tutorial, worked a treat!
>>X<< Wrote:I think he might be referring to adding the playlist created to favorites first which of course you must do
You might be right. I guess it's one of those things that's easy to do and hard to explain.
Thanks everyone, this has allowed me to add a "Kids movies" playlist entry on the home menu.
The only problem is that these "Kids movies" are still part of my main Movies library. Is it possible to exclude these from my main Movies library?
I realise I could create 2 playlists (Kids movies and Parents movies, for example), but then I would lose the features of the main movies library, like Recently Added. I wish XBMC would finally add the ability to have multiple libraries...
rickles Wrote:I realise I could create 2 playlists (Kids movies and Parents movies, for example), but then I would lose the features of the main movies library, like Recently Added. I wish XBMC would finally add the ability to have multiple libraries...
What do you mean your lose features do you mean if you remove movies from the main menu your lose the features that are in the sub menu, because just using a playlist for your movies wouldn't lose you features :confused2:
If you want Movies to take you directly to your playlist for example one that excludes your kids movies your need to edit line 2012 and 2356 in the "Includes_Home.xml"
I use one for HD movies so would need to replace
<onclick>ActivateWindow(VideoLibrary,movietitles,return)</onclick>
with
<onclick>ActivateWindow(10025,special://profile/playlists/video/HD Movies.xsp,return)</onclick>
You can get the path from your "favourites.xml" if you add the playlist to favourites
