Full Version: Installed 10.0 - Can't connect to LAN
All
I 'Finally' installed XBMC 10.0 onto my Acer Revo after messing about for a while.
After installing XBMC 10.0 i can't access the LAN either at work or at home.
Internet access is also a dead end.
All settings are default.
Erm... Help.
Some dumb questions....
This is a wired connection? LAN is turned on in the Bios? Have a connectivity light/link? Did it connect to your LAN before installed xbmc? And what OS are you on?
ptmuldoon Wrote:Some dumb questions....
Hello
Wired connection.
LAN on in BIOS.
Connectivity light is green.
Worked perfectly with the last full installation of XBMC.
OS version is XBMC 10.0
All worked fine until i re installed with the new 10.0 Operating system
Try doing the install over again ? Maybe with another media ?
