Have installed xbmx 10,0 dharma live final.
Just wondering how i can access the context menu with my mce remote.
After some searching it looks like i need mce remote addon but i can´t find it in the download addons section within xbmc.
Thanks in advance.
/Jerry
It should be the key "title", depending on your remote, the look of the button itself will be different. On mine (pinnacle media center kit) it looks like a little menu with lines of text.
You can find mce remote addon under the Program section.
StarChild Wrote:You can find mce remote addon under the Program section.
... only if you're using Windows. It's tagged as "Windows only" because works by configuring the eHome device driver. On Live you have to fiddle with remote.xml or the LIRC config in some way that I only vaguely understand.
JR
Thanks for your answers but all of the sudden i appears that the "guide" button open the context menu.
I swear it didn´t work before, i went through every single button to see what it did.
Ah well, as long as it works now
Thanks again
/Jerry
