Full Version: Update beta to official release
I rebuilt my Acer Revo 1600 with XBMC Live a few days before the official Dharma release. It works like a champ but occasionally hangs especially while playing Grooveshark or Pandora. Does anyone know if this is a plugin issue or if this is because of XBMC (beta) and has been fixed in the final release? I suspect it is the plugin but wanted to try updating XBMC just to rule that out.
However, I am not sure if I can do an apt-get update via putty or if there is an easier way within XBMC (via an add-on) to upgrade XBMC itself?
Thanks for any pointers.
apt-get update xbmc
via terminal is still the way to go as long as you have the proper ppa added
Hannes The Hun Wrote:apt-get update xbmc
Oo
GODDAMMIT I did it again!
FIRST
Quote:sudo apt-get update
THEN
Quote:sudo apt-get install xbmc
[sudo apt-get upgrade will update ALL packages]
