fade23 Wrote:The various views that use TV logos look really great, but since those logos are the only indication of the name of show, it would be nice if the skin would just display the show title as text if logo.png is not present. I know I could always make a placeholder logo.png, but it would be good if the skin had a fallback.
Yes I noticed this yesterday. On landscape for example, using logos, if the logo is missing you have no indication of which show you are looking at.
I apologise for this and feel so stupid but for the life of me I can't find out where to download this form. It's no longer in the XBMC repository and for the life of me I can't find the .zip file to upload.
Can anyone please point me in the right direction please?
PetSue Wrote:I apologise for this and feel so stupid but for the life of me I can't find out where to download this form. It's no longer in the XBMC repository and for the life of me I can't find the .zip file to upload.
It's here:
Install skin through XBMC addon repository:
Addons--> Get Addons --> XBMC.org addons--> Skin--> Aeon Nox
Unless your using a nightly build? I don't think it will show in the repository if your using a nightly so then you will need the pre-eden version from git here:
https://github.com/BigNoid/Aeon-Nox/zipball/master
Mindzai Wrote:Yes I noticed this yesterday. On landscape for example, using logos, if the logo is missing you have no indication of which show you are looking at.
That's why there are breadcrumbs. And List and Info List do show the TV Show title. Maybe in Landscape view I could set the show title in the top of the panel, like the tagline with movies. I cannot know if there is a logo or not, so I can't use a fallback label.
Nemrod Wrote:Hi,
Thanks for your answer.
For the main menu, indeed, i see that it work with an option in the settings. What do you mean by dynamic content ? The only menu left with this problem is the sub menu.
Nemrod
Forgot about the submenu's. Dynamic content is movies titles etc.
You can also use the passion xbmc repo:
http://passion-xbmc.org/addons/Download....-1.0.4.zip
smiffy1989 Wrote:Install this:
Favourites Script for pre-eden: http://mirrors.xbmc.org/addons/eden-pre/...avourites/
I don't think it is installing, I am not getting a conformation. everything appears as it was after reboot, must be missing a step. Running ubuntu 11.04 unstable ppa.
smiffy1989 Wrote:It's here:
No not using the nightly build and for the Apple TV 1 & 2 it's not in the XBMC repository sorry.
Big_Noid Wrote:That's why there are breadcrumbs. And List and Info List do show the TV Show title. Maybe in Landscape view I could set the show title in the top of the panel, like the tagline with movies. I cannot know if there is a logo or not, so I can't use a fallback label.
I prefer not to use breadcrumbs, so in landscape there's currently no title at all for me. Showing it at the top of the panel sounds like the best solution imo, perhaps only showing it for those with breadcrumbs disabled (as it would be redundant with breadcrumbs enabled).
Minor Bug: When setting a new numeric or text lock for a source, the popup appears behind the other dialogs making things hard to see.
Shinu Wrote:Minor Bug: When setting a new numeric or text lock for a source, the popup appears behind the other dialogs making things hard to see.
What version are you using, 1.3.0 or higher? It should be fixed in 1.5.0 and git.
For the clearart logo for music artists, where should we put them and what should the filename be? Is it the same as TV, in that logo.png at the root of the artist directory? I know for cdart it is "cdart.png" inside the album directory.
fional Wrote:For the clearart logo for music artists, where should we put them and what should the filename be? Is it the same as TV, in that logo.png at the root of the artist directory? I know for cdart it is "cdart.png" inside the album directory.
I implemented it with the cdart manager script in mind. The same path should be set in viewtype options as it is set in the cdart manager script (path to music library). Then run the script and enjoy the logos. Only in svn and git currently btw and only in lowlist and infowall.
Big_Noid Wrote:I implemented it with the cdart manager script in mind. The same path should be set in viewtype options as it is set in the cdart manager script (path to music library). Then run the script and enjoy the logos. Only in svn and git currently btw and only in lowlist and infowall.
Lowlist is my preferred view!
I can't wait to see the CD-Spin in there too, rather than just list view. I was just organising my music, now that I'm done with movies and tv-shows, thought I'd get it ready for the official release - but since I also use cdart manager, it'll be a breeze!
Many thanks Big_Noid!
Big Noid,
The new stripshow view in epsiodes looks great
Have some small remark:
Chapter (hoofdstuk) in bottom left corner little bit off screen.
