Hello to all of you.
I've made a Russian Translation of Aeon Nox skin. Not full, but around 80-90%
Here is the link for
strings.xml
It would be nice if it could used.
Big_Noid Wrote:The color scheme Lite_Floor is meant to be only used in conjunction with the theme Lite_Floor.
Has that theme not been added yet? Have only the standard to choose from
Heckfy Wrote:Hello to all of you.
Here is the link for strings.xml
Thx, is for the dharma release or for the eden-pre version?
There's no slider knob in theme "Lite Floor" for the views carousel and posters.
Have both theme and coulor at "lite floor" however the floor text is very hard to see, especially at the sides.
With normal color it much better.
Big_Noid Wrote:It's not a flag, its an option to show info about subtitle/audio stream instead of other info. Its an option in the media menu. It's a bit crippled though because XBMC will only show the first embedded subtitle and audio stream. It doesn't detect srt files.
OK. I'll dig into it a bit more. What is used for detecting the embeded subtitle and audio stream?
frodo19 Wrote:Hello Big_Noid !
I've made Hungarian Translation of Aeon Nox skin. used XBMC vers 10.1
Here the link : http://www.sendspace.com/file/ljgy9r
Thanx for your work on the Skin..
Added, will be in next update. Thx
Big Noid,
In visualisation settings the numbers are missing.
Machine-Sanctum Wrote:Big Noid,
I guess this is an xbmc bug. It's also missing in Confluence. None of the options do anything.
Big_Noid Wrote:I guess this is an xbmc bug. It's also missing in Confluence. None of the options do anything.
Must be since one of the latest builds.
Has the trailer label been removed from latest movie widget? Doesn't seem to show for me now.
Hudson_Hawk04 Wrote:wondering if you had thought of switching to media info flags that have more color, hes some that I found.
http://forum.xbmc.org/showthread.php?tid...edia+flags
Yeas I have considered it, but I like the white flags and what you can do with them in terms of color diffuse better than the colored ones. It's easy to replace them yourself though.
smiffy1989 Wrote:Has the trailer label been removed from latest movie widget? Doesn't seem to show for me now.
Yep. Fixed that just now.
