kees667 Wrote:wow, great skin! tried it on my asrock 330 with ssd. ran Mq2 before but didn't feel fluent enough, I really like the feel and responsiveness here.
two points of feedback:
1) When scrolling in the main menu I notice that some pictures appear sooner than others. I tried this on pictures, the background (motobike) takes some time to show. If I then scroll to the next item, and back than suddenlty the background (motorbike) will instantly reappear. If I browse "full circle" and reach pictures again then it is slow again. Appears as if it caches only a few backgrounds?
Weird thing is that I liked the slow appearance at first, and then noticed that some others are fast, kind of weird.
2) what does flatten do? in movie (library) mode I get sent back to main menu when I enable it, then when I go back I don't spot any difference, could be me. In music (fileview) I can turn flatten on/off without going back to main menu but I don't see any changes.
keep it up and thanks!
1: I can't reproduce this. Every background is faded in 1 second on my system.
2: The flatten button is standard XBMC functionality:
Flatten library (hide sub-catagories, like genres, studios, years, etc...)
So it's true most of the time you won't see any difference, since the main menu button takes you straight to title view.
Death-Axe, tboooe and Dascmo:
lol, I just added that to svn just before your messages!
Microsaft Wrote:At least in main menu it does not work. I was stuck there - no chance to do anything or switch back. It was not possible to select and click on anything in the main menu but e.g. to swipe left (=backspace) worked fine.
Your skin is light enough to work fine with iOS devices. Would be great to have it on the iPad....
I really haven't got a clue where to begin to add touch support? Also I don't have a device to test with. Hopefully XBMC will be ported to android some time soon so I can start testing.
itsmeee Wrote:I just tested it out a bit. I got no problem with MediaStream Skin or Xperience Skin which I use at the moment. Every Movie format works there.
At the NOX skin every DIVX and DVD movie works in every View (Showcase, List, Wall ...)
720p and 1080p Movies work most of the times in Showcase, Low List, List and DVD Case view. Not in Landscape and Wall View.
Sometimes it crashes in Showcase too. When this happens I can see a flipping movie info which turns around really croppy. Then it crashes. Most of the times I don't see this movie info at all - then it works.
Would it be possible (or is it allready) to turn of those animation in the system skin settings?
thanx for your effort
cheers Gernot
I really doubt this is a skin problem, and you're likely to have this problem some time soon in other skins as well, but you can go to Includes_Showcase.xml and delete the animations that start with these lines:
<animation type="Conditional" condition="Player.HasVideo" reversible="false">
and
<animation type="Conditional" condition="!Player.HasVideo" reversible="false">
lol @ all the banner requests
I think I will add a banner wall view, but it's not a priority atm.
GuySie Wrote:Awesome skin! I've been in love with Aeon since forever, but an aTV1 doesn't have the power to run it. Nox works perfectly though. Took me less than a minute to decide to bounce my perfectly working Confluence setup for this.
One question that's probably only relevant for me: can I edit a file somewhere so the shutdown button on the main menu actually reboots the system? The aTV1 has no power down functionality so shutdown puts it into some odd unresponsive mode where it's still on but I can't even SSH into the system anymore, and I need to physically disconnect the cable to start it up again. Reboot makes more sense for me.
There is already Restart in submenu of Shutdown which does just that. if you want the shutdown main menu to restart you'll have to edit the Home.xml since XBMC doesn't have restart function in Shutdown function:
find
<item id="12">
<label>13005</label>
<include condition="!Skin.HasSetting(shutdownwarning)">NoShutdownWarning</include>
<include condition="Skin.HasSetting(shutdownwarning)">ShutdownWarning</include>
<icon>special://skin/backgrounds/shutdown.jpg</icon>
<thumb>$INFO[Skin.String(Home_Custom_Back_Shutdown_Folder)]</thumb>
<visible>!Skin.HasSetting(HomeMenuNoShutdownButton)</visible>
</item>
and change to:
<item id="12">
<onclick>Reset</onclick>
</item>
