Very nice
I got it and things are running nicely.
In Viewtype_LowList.xml, in TV Shows:
When I was browsing TV Shows, it would show me the
Plot (as it does now)
and below that
The total amount of episodes (watched/total)
and below that
The path to the files.
When I went to season view, it did the same. Though the total amount of episodes is redundant, the path to the files is important to me.
Now, I've been able to adjust it so when I go into episode view, it shows me the proper path. Basically it uses the same view as it does in the movies, so I got that part working.
Thing is, with the TV shows, I can't figure out where it goes now - because the markers I was using to figure it are gone/changed
I've tried several things the past 3 hours and I only result in bugging it so bad that LowList doesn't even load, rather it defaults to list!
Basically, what I used to have was something similar to:
Quote:<control type="label">
<posx>850</posx>
<posy>600</posy>
<height>13</height>
<width>430</width>
<font>Font_Info</font>
<textcolor>abFFFFFF</textcolor>
<label>Drive:</label>
<visible>!Skin.HasSetting(highlist)</visible>
</control>
<posx>960</posx>
<posy>600</posy>
<height>13</height>
<width>220</width>
<textcolor>white</textcolor>
<label fallback="Outer Space">$INFO[ListItem.Foldername]$INFO[ListItem.FileName]</label>
</control>
Now, the x pos is going to be off, but I know how to tweak that, I just don't know where it goes now
Basically, I figure I could shorten the plot box (somehow) 2 lines worth, what's that, a figure of 50? and have these two sections beneath it in TV Show view and Season View.
Same with:
<posx>850</posx>
<posy>575</posy>
<height>13</height>
<width>430</width>
<label>$LOCALIZE[20360]:</label>
</control>
<posx>960</posx>
<posy>575</posy>
<height>13</height>
<width>220</width>
<label>$INFO[ListItem.Property(TotalEpisodes)$Info[ListItem.Property(UnwatchedEpisodes), ($LOCALIZE[16101]: ,)]</label>
</control>
Now, if there's a typo in there it is because I'm retyping it and not using cut and paste (on my mobile so...)
Sorry for the bother, I'm just terrible at sorting these out it seems.
