i really don't mean to keep bringing up the same issues over and over, but...
Shinu Wrote:were u able to fix the issue with the poster not appearing in the episode for shows with 1 season?
Proberly overlooked between other post so
Quote:Some minor thing
Have a couple of movies have this <codec>microsoft</codec> after scraping with Ember.
In panelview it has the ? as video codec and WMA audio
Infoscreen while playing has WMV-HD and ? audio
After playing it some time it stays the same.
Movie set isues:
while on a collection in panel view some flags do show.
same in list view
poster view show ? rating
Other view don't show flags.
Shinu Wrote:i really don't mean to keep bringing up the same issues over and over, but...
I have Firefly and Caprica. Both show series poster in episode view.
i also have Caprica, and i see no poster....
i don't understand what the problem could be. it worked fine when it was first implemented.
seriously, is no-one else experiencing this issue?
Looks
fine here, probably has something to do with season folders? What's your file structure?
Hi Noid,
Had this issue for a few days and updates and it doesnt appear to have been noticed yet.
In tv shows, landscape view with the logos layout, the info doesn't show up. works fine with the other two layouts.
Cheers.
sergiocos Wrote:Looks fine here, probably has something to do with season folders? What's your file structure?
Folders are fine. Set up the same as series with multiple seasons.
As I said, it worked up until recently. I was wondering if the issue could be due to the media being on a network? Just brainstorming.
Shinu Wrote:Folders are fine. Set up the same as series with multiple seasons.
Have you tried removing the series and readding it?
well it happens to every series with only 1 season, not just Caprica. so i'm at a loss.
Hi Big_Noid,
Thanks for all your great work on the skin. I'm running the SVN version of the skin, and noticed a freeze bug introduced about a week ago.
When using an addon such as YouTube or Vimeo, and using the search function, a freeze occurs.
This only occurs when creating a new search. Using an already-made search does not reproduce the freeze.
Steps:
1. Start YouTube or Vimeo
2. Enter Search menu
3. Create a new search
--- Keyboard screen appears
4. Enter some text
5. Submit
--- Keyboard screen disappears
--- Loading notification appears
--- Freeze (throbber stops spinning)
Can anyone else reproduce this?
@ Noid
On latest Git version.... No OSD PLay stop buttons
icky Wrote:@ Noid
You can enable them using settings (the most right button)
Machine-Sanctum Wrote:You can enable them using settings (the most right button)
cheers for that..... skin is definitely looking more streamlined now!!!!
asha_man Wrote:Hi Noid,
Cheers.
I cannot reproduce this one.
Shinu Wrote:well it happens to every series with only 1 season, not just Caprica. so i'm at a loss.
What are your settings for flatten tvshows?
icky Wrote:cheers for that..... skin is definitely looking more streamlined now!!!!
I forgot to make it default off, so there's a change after an update you have to enable/disasble the setting again.
yukky Wrote:Hi Big_Noid,
Steps:
4. Enter some text
5. Submit
Yeah I had this also, but I figured it was the youtube add-on. Will investigate some more.
Machine-Sanctum Wrote:Proberly overlooked between other post so
Will look into it.
