Big_Noid Wrote:Okay I misread I think. It is indeed intentional, they are slightly more diffused as the focused items. Same on the submenu. Because of the wrap list I think it's clear enough which item has focus and I really like the contrast between the white and dark.
I thought you meant when you press "S" the focused item is diffused, but not the unfocused items. That's something I meant to change but other stuff keeps popping up in my head
I hope you finish the entiry skin with Auro theme (eventually ofcourse)
@Big_Noid
sorry one question again. Is there any chance to see if a movie have a trailer in DVD Case view without enter the info ? See and start trailer like the last movie widget ?
Greets
Eisi
Eisi2005 Wrote:@Big_Noid
thx for the help that works
One last Question, did you know where i could adjust that ?
Last you would probably have to adjust the height of the list to not overlap the widget background texture
Greets
Eisi
Yeah in IncludesHomeRecentlyAdded.xml where you put the extra items. The lists that holds those items now have height 292, which should probably be less.
Machine-Sanctum Wrote:I hope you finish the entiry skin with Auro theme (eventually ofcourse)
If some skilled graphics artist is around to help me would be very nice.
Greets
Eisi
Should already be available, but to see the markers you would have to enable trailer label or breadcrumbs.
@Big_Noid
long time i didnt post in your topic, nice to see you got your own subforum.
I keep track in your skin, the best aeon version around, i read about the aura theme and i remember something i did, you can use if you want, just ignore clock if you dont like it, i think you need match fonts and color too.
Well is not that much but is a start xD, if i got some free time i can make more, cant promisse since im building my onw skin but sometimes my mind play around and goes to other places and create random stuffs.
PSD File
http://www.mediafire.com/?5qo315bp5h9xw48
Cheers
Middle Wrote:Well is not that much but is a start xD, if i got some free time i can make more, cant promisse since im building my onw skin but sometimes my mind play around and goes to other places and create random stuffs.
Cheers
Looks great! It's definitely a start. Thx
Middle Wrote:@Big_Noid
PSD File
Cheers
That clock is sweet. Maybe change the font to match the main menu bar.
Middle
Something is not right in that screenshot
The big clock says 21:20 and the small one on the menu bar 13:15
Machine-Sanctum Wrote:@Middle
got me!
it is not coded the image is from psd file, and background is a real screenshot from xbmc.
i did this sometime ago, but i decide not build my skin in white so i didnt finish code.
i will try make more, i wondering how showcase in white will look like.
Middle Wrote:got me!
lol well i have an eye for detail
I'm hoping Noid will find some time eventually (or someone helps him) so i can make a script that will switch the theme in Nox depending on time of day
Aura at daytime and Dark at nighttime
htpc guy Wrote:I can has?
I will commit my progress, but you would have to build the theme yourself and it is no way near finished.
