Big_Noid Wrote:Yeah, maybe a redesign for that infopanel is needed. Autoscrolling is a setting in the general skin settings btw and applies to all textboxes throughout the skin.
Would be much appreciated!
Just checking out 2.0 on Eden beta 2.
I've noticed the NEW icon appears on shows without any episodes in them.
Also, I was wondering if it's possible to get AeonMQ3's context-specific random fanart as the background images for tv shows and films?
Thanks, that works great
MQ3 has a new feature where, once viewing a film or tv show in their respective sections, the fanart is randomised (you must be using extra fanart downloader). Any chance of the same with Aeon?
Also, is it possible to set Showcase to wrap around?
Rumik Wrote:Thanks, that works great
Both option in de MediaMenu (that left pop out menu).
Enable Extrafanart and Navigation: wrap list
Hi there,
I'm clearly an idiot, thank you for being so patient
The NEW icon (watched too) on empty tv shows is annoying tho :p
Rumik Wrote:Hi there,
Why you want to show empty series? You can hide them with hideemptyseries tag in advancedsettings.xml. Will check if there's something wrong with the code, cause it's coded to only show the flag on tv shows that have an episode in the 10 last recently added list or for every unwatched item, depending on the setting.
Hideemptyseries? Great I'll try that, thanks
That worked brilliantly, thanks. One last thing before I leave you alone... Is there a Next Episode widget for the home screen that suggests what episode you should watch next based on what you've already watched? I heard there was something like that but haven't found an option for it.
Rumik Wrote:That worked brilliantly, thanks. One last thing before I leave you alone... Is there a Next Episode widget for the home screen that suggests what episode you should watch next based on what you've already watched? I heard there was something like that but haven't found an option for it.
Enable widgets in skins settings and then choose: show unwatched episodes of currently watching tvshows
You mean the "choose which media widgets to show on Home window" option? I don't have the "show unwatched episodes of currently watching tvshows" option
Rumik Wrote:You mean the "choose which media widgets to show on Home window" option? I don't have the "show unwatched episodes of currently watching tvshows" option
and you do have other widget to choose from there?
Yeah, several, like show random movie widget, poster widget, tv show widget, etc. just not that one you suggested
Rumik Wrote:Yeah, several, like show random movie widget, poster widget, tv show widget, etc. just not that one you suggested
OK maybe the script didn't get installed somehow.
Install this manually by using "install from .zip" in the addons section.
http://mirrors.xbmc.org/addons/eden-pre/...watchlist/
Hmm. I installed it like any other zip file but it didn't tell me it had finished, nor does it show up in programs or addons (if it's an addon, what category will it come under?) and it hasn't added anything to the widgets list. The folder and files were definitely copied over from the zip file, though.
