2011-04-02, 10:44
Shinu Wrote:hey noid. can u revert the default aspect ratio for videos to what it was before? for some reason, all videos played through using addons has their screenshot (in the fullscreen info view) showing with a poster's ratio instead of the normal 16:9 ratio they should be.....I believe this somehow is a bug in xbmc, because the visibilty condition states that it should only show poster when the videoplayer content is movies. But indeed when playing addons it somehow thinks it's content are movies?
the thumbs when using the infowall for addon and non-library videos have the wrong ratio.
Shinu Wrote:oh and there's no background visible when accessing the videos files screen.fixed.
b_cott Wrote:i LOVE this theme. Just got it on my AppleTV2.Select Showcase view or DVD case view in the media menu which can be accessed by pressing in the opposite direction of the list navigation. It's better to scan your items to the library though then to work with the file view.
Can someone tell a noob how to go from folder and file select for movies to showing up with the coverart in a "coverflow" style with all the info?
Babal Wrote:Understood, thanks for the explanation Big Noid.I tried to yesterday, but I couldn't find a good solution. When I have time, I'll try to workaround this problem.
Is there any way to implement a way to change the fallback image without unpacking, or encountering the same problem?
