2011-01-02, 08:20
Arch linux user here, my xbmc package info is:
Have gone through the entire settings, add-ons and configured the heck out of this thing, can't get Myth working as a video source, and the Mythbox add-on gives an "Unsupported protocol" error.
Used this link: http://www.mythtv.org/wiki/Xbox_Frontend...deo_Source
I have the IP/MySQL settings correct as I use laptop and other PCs as frontends, and I even rechecked all settings (/etc/mysql/my.cnf, restarted mysql, checked mythtv-setup > local backend IP, etc.) but I can't get it to work. I use this when adding video source:
But I keep getting this: screenshot1 screenshot2
Here is some of the log with debugging on:
And here is shell output when running xbmc for what it may be worth:
(I do not have Samba configured at the moment).
Thanks for any help folks!!
Version : 10.0-2
URL : http://xbmc.org
myth://mythtv:[email protected]
00:42:05 T:3023480704 M:2319089664 DEBUG: CGUIMediaWindow::GetDirectory (myth://mythtv:[email protected]/)
00:42:05 T:3023480704 M:2319089664 DEBUG: ParentPath = []
00:42:05 T:2905201520 M:2319106048 ERROR: GetControl - unable to connect to server on 192.168.1.100:6543
00:42:05 T:3023480704 M:2319106048 ERROR: GetDirectory - Error getting myth://mythtv:[email protected]/
00:42:05 T:3023480704 M:2319106048 ERROR: CGUIMediaWindow::GetDirectory(myth://mythtv:[email protected]/) failed
00:42:05 T:3023480704 M:2319106048 DEBUG: CGUIMediaWindow::GetDirectory ()
00:42:05 T:3023480704 M:2319106048 DEBUG: ParentPath = []
00:42:05 T:2927590256 M:2319106048 DEBUG: thread start, auto delete: 0
00:42:05 T:3023480704 M:2319106048 INFO: Loading skin file: DialogOK.xml
00:42:05 T:2927590256 M:2319106048 DEBUG: Thread 2927590256 terminating
00:42:05 T:3023480704 M:2319106048 DEBUG: ------ Window Init (DialogOK.xml) ------
00:42:06 T:3023480704 M:2319978496 DEBUG: SECTION:UnloadDll(libcurl.so.4)
00:42:06 T:3023480704 M:2319978496 DEBUG: Unloading: libcurl.so.4
00:42:06 T:3023480704 M:2319986688 DEBUG: SDLKeyboard: scancode: 36, sym: 13, unicode: 13, modifier: 0
00:42:06 T:3023480704 M:2319986688 DEBUG: OnKey: 61453 pressed, action is Select
ΓΆΓΆ> xbmc
params.c:OpenConfFile() - Unable to open configuration file "/home/bobby/.smb/smb.conf":
No such file or directory
params.c:OpenConfFile() - Unable to open configuration file "/etc/samba/smb.conf":
socket(): Address family not supported by protocol
(cmyth)cmyth_conn_connect: asked for version 8, got version 63
(cmyth)cmyth_conn_connect: asked for version 63, got version 63
(cmyth)__cmyth_rcv_length: read() failed (0)
(cmyth)__cmyth_rcv_okay: cmyth_rcv_string() failed
(cmyth)cmyth_conn_connect: cmyth_rcv_okay() failed
