Full Version: XBMC freezing when hitting Play (Rapier qualar mod)
I can't tell if it's the skin or XBMC itself, but I get random freezes when playing a movie. Doesn't seem to matter if it's an MKV or AVI.
While browsing in Wall View, I press enter on the MCE remote to play a movie and the text pops up NOW LOADING and it freezes right there on that screen. XBMC becomes unresponsive and I have to CTRL-ALT-DEL to get out.
I have three logs, two were when playing locally-stored files, and the other was a file on the network:
Local video 1
Local video 2
Networked video 1
All three logs end with these lines:
18:37:39 T:3820 M:1497092096 ERROR: CThread:ConfusedtaticThread : Access violation at 0x6ae817c3: Reading location 0x00000124
18:37:39 T:3820 M:1497092096 NOTICE: thread end: video_thread
thanks for any help.
Just a thought... but if this is happening often, try a different skin. If it stops happening than you found your problem, if it keeps happening (which I think it will) than you need to ask in general help section where you're more likely to find someone with the technical expertise ^_^.
