Full Version: R3610 and Harmony
Hi all,
I have one acer r3610 with xbmc dharma in windows 7. It works very very well.
But now i bought a harmony 515 (i have one MCE IR receiver) and i want to know how to setup the remote on logitech harmony driver and make a activitie to open xbmc. I also want to know if it is possible turn on and turn off acer revo with the remote?
Thks
If the receiver you have is a Microsoft or Microsoft compatible you just need to configure the Harmony to emulate the MS handset or a MS multimedia keyboard (both work).
You should find that the power button on the remote handset will put your Revo into suspend and wake it again.
JR
The following is a little out of date due to software versions, but you should be able to figure it out.
http://forum.xbmc.org/showthread.php?tid=77519
Thanks!! The tutorial helped a lot. Now I have it working almost perfect.. I configure like a MS multimedia keyboard, didn't understand why on that tutorial you need to add two devices..
