Just upgraded to 10 and am loosing my sound, some movies play correct but others do not once one is selected that will not play correct, nothing will play sound from that point including menu sounds. All content is the same file format, all ripped the same exact way, and to the best of my knowledge worked with 9.11 just fine. Any help is appreciated
Which version of the ATV OS are you using? I had a problem very similar and found that I was on an older rev of the ATV OS. Once I upgraded to 3.02 (IIRC) and reapplied the patchstick, I gained audio continuity through the menu and from one file play to another.
I will give it a look and let you know when I get home. Thanks for the help in advance
Gave it a look and I am at 3.0.2, so that is not it I guess (wish it was at least I would have something to try
