Full Version: [Live] Can't get wifi work on 10.0 Dharma
I can't get a wireless connection on xbmc live 10.0.
During the install, I gave the SSID of my router. But that didn't work. Then i tried on the old way.
I used this tutorial to setup wireless internet connection
But i can't update it even with a ethernet cable connected!Sad
And when i enter this code:
wpa_passphrase myHomeNetwork mySecretPassword >> /etc/wpa_supplicant.conf
It gives me an acces denied. I also can't make changes on /etc.wpa_supplicant.conf. I'm somehow not allowed to make changes.:confused2:
Can somebody help me??
I use a usb wifi adaptor. A Sweex 54G LW053 Adaptor. The adaptor got a ralink RT2571WF chipset.
THNX!Cool
Sorry for my bad english.
when you get permission deny you need to start the command with 'sudo'.
if you messed up the network config during install wired will not work...for some reason the installer do not put in any default config when it fails. You either fix it manually or re-do installation with wire connected.
When that is done you can try this instead to get wifi going.
http://forum.xbmc.org/showthread.php?tid...icd-curses
