Just install the new skin on my Dharma XBMC on my Ubuntu 10.10 and it looks great.
When I go into the Movies library and choose the WALL view I get the movie information display (mark in red).
How can I disable it? it's pretty annoying !
Can you access the options bar that is supposed to appear on the left (go to e.g. Avatar and press the up arrow key once more, at least this works for landscape view)? I think you can disable it there.
I already looked in there,but I couldn't find anything that will disable it completely.
Only thing I was able to find under the settings is a "hide plot for unwatched movies" that prevents the movie's plot to spears in the movie's information and by that avoid spoilers.
On the options bar select 'Mode' under 'Info Panel' and set it to 'Off'
That was easy.
Problem solved.
Thanks james.
