Full Version: Problems with MAC Mini
OSX Version10.6
Platform Apple MAC Mini
Install Method dmg
SVN Revision (See below.)
Detailed Instructions to Reproduce the Problem
Unable to stream MKV files from my NAS (DLINK 343) to the MAC Mini using XBMC. Also NETFLICKS does not work Script error code appearing at the bottom right corner.
GUI Problems: None
Skin name: Confluence
Playback Problems: MKV Netflicks
Video codec and container. MKV
Audio codec and container. Audio MP3 seem to work fine
Other things that may be useful:
System hardware specs Mac Mini running OSX verson 10.6.5 Intel Core 2 Duo 2.4GHZ 5 Gig of RAM
How do I find my architecture?
i386
My SVN revision number
10-OR35648 December 2010
SKIN Confluence
debug log http://en.pastebin.ca/2037910
First read :
http://forum.xbmc.org/showthread.php?tid=87749
Second:
On your NAS, do you have SMB or AFP installed ? If you have the option to install AFP than do.
Third:
In your movie section select add source and point to the NAS. When the source is added play the file from your NAS.
Goodluck
Thanks its works now, except I now realize that the Mac Mini 2010 does not handle HDMI DTS or Dolby very well. Maybe you have some insight on what I should do to make it work.
Vox
Voxpopuli Wrote:Thanks its works now, except I now realize that the Mac Mini 2010 does not handle HDMI DTS or Dolby very well. Maybe you have some insight on what I should do to make it work.
Vox
Um...thats not true. HDMI DTS and AC3 Passthru works perfect on my 2010 Mac Mini. In addition, you shouldn't be running 10.6.5 with XBMC. You shouldn't run anything past 10.6.3.
Search and you will see why.
Ok I see. I just bought the Mac Mini and in checking the installation disk I have 10.6.3 so I will install. Thanks again for your help.
