Full Version: [Crystalbuntu]Atv gets weird time out when playing video
Sometimes, mostly right after a reboot I get a black screen for 1 or 2 min when trying to start a video. First I thought that it was only on 720p but I get it with other files and when opening a stream as well. It just happened and my xbmc.log says the following:
11:40:16 T:3043510112 M:124719104 WARNING: CreateFile, successfuly opened </home/xbmc/.xbmc/addons/skin.alaska.revisited/720p/DialogSeekbar.xml> instead of </home/xbmc/.xbmc/addons/skin.alaska.revisited/720p/DialogSeekBar.xml>
11:41:17 T:2952895376 M:121622528  NOTICE: ES: Client  from 127.0.0.1 timed out
Is there someone with the same problem. I stream al my video via samba or in this case the internet (NOS Journaal plugin). Is there a way to fix this problem?
I dont want to open another topic, but this is also bothering me:
file: /media/music/Spinvis/Dagen van Gras, Dagen van Stro//cdart.png
19:31:23 T:3043415904 M: 93016064   ERROR: Initialize - device plug:iec958 busy retrying...
19:31:23 T:3043415904 M: 93016064   ERROR: Initialize - pcm_open_lconf, alsa error: -16 - Device or resource busy
19:31:24 T:3043415904 M: 93138944   ERROR: Creating a Null Audio Renderer, Check your audio settings as this should not happen
19:31:31 T:3043415904 M: 82055168   ERROR: Texture manager unable to load file: /media/music/Spinvis/Dagen van Gras, Dagen van Stro//cdart.png
19:32:34 T:2952801168 M:123244544  NOTICE: ES: Client  from 127.0.0.1 timed out
I get this error sometimes when changing audio files, manually or automaticly. I have my receiver hooked up via the optical output of the apple tv. I have my settings set to optical/coax, speaker config 5.1, boost volume level on, AC3 and DTS capable and audio output device is iec958 and passthrough also on output.
I'd prefer to use hdmi audio to my tv and then from my tv with optical to the receiver (I only have one optical input on my receiver and I have to share it with my xbox360). But I dont know what settings to use, it doesnt seem to work for me.
While I'm at it. DDS art sometimes fails as well, it just disappears and doesnt come back until I start/exit a movie.
