Full Version: fading OSD buttons fade is set where?
the three buttons in osd for video that indicates which part of music/video/subs settings youre in are currently fading back and forth slightly.
where is the value for this set?
i can't find it in videofullscren.xml and i can't figure out if it is a setting that comes from reference.xml.
if you check out my skin retro and the solution i made for the osd buttons, it doesn't really work with the fade.
any help appriciated...
/floink
an observation... but i'm not sure. is this fading effect applied to all elements that are currently in focus/selected in the gui?
and again is this behaviour editable? does it have to do with <fadelabel>?
/floink
bump... just an "u can't edit it (right now)" would do Image
/floink
(floink @ jan. 15 2004,21:05 Wrote:bump... just an "u can't edit it (right now)" would do  Image
/floink
i give you a "dunno" for the meantime. Image
